Setting DB2 Configuration Parameters for DB2 HADR Using IBM Tivoli System Automation (TSA) with a Virtual IP Address
You can configure the primary and standby database by using the DB2 command line interface.
Primary Database
  • Use the DB2 command line interface to configure the following DB2 parameters.
    Substitute the Primary_Database_Name parameter with the name of your primary database.
    Substitute the CVClientName parameter with the Virtual client name.
    db2 update db cfg for Primary_Database_Name using TRACKMOD on
    db2 update db cfg for Primary_Database_Name using LOGARCHMETH1 "'VENDOR:software_instalation_location/Base/libDb2Sbt.so'"
    db2 update db cfg for Primary_Database_Name using LOGARCHOPT1 "'CvClientName=Virtual Client Name,CvInstanceName=Instance001'"
    db2 update db cfg for Primary_Database_Name using VENDOROPT "'CvClientName=Virtual Client Name,CvInstanceName=Instance001'"
    db2 update db cfg for Primary_Database_Name using LOGINDEXBUILD on
    db2 update db cfg for Primary_Database_Name using INDEXREC RESTART
Standby Database
Automatically Updating DB2 Parameters
You can automatically update DB2 parameters by using the Db2_config.sh script on Unix and the Db2_config.ps1 script on Windows to perform backups and restores.
The following DB2 parameters are modified:
  • LOGARCHMETH1
  • LOGARCHOPT1
  • VENDOROPT
  • LOGARCHMETH2 to OFF
  • TRACKMOD to ON
The following table defines the parameters for both scripts.
Parameter
dbname
The name of the DB2 database. This is required.
Client Name
The client name of the cluster.
Commvault_Instance
The name of the Commvault instance. This is optional. When you do not specify this parameter, the Commvault software uses Instance001.
Using the Script on UNIX Clients
This script is available in Commvault_path/iDataAgent on the UNIX client. This script can be used to set the DB2 database configurations to use Commvault DB2 on UNIX iDataAgent to perform a data backup on a single node DB2 Instance, log backup and log archival. This script also checks if the instance user has read/write permissions to the Archive, Retrieve, and Audit error directories. You must be a DB2 instance user and need to be added to the UNIX group of Commvault to run this script.
Db2_config.sh -d dbname -c cluster_client_name [-i Commvault_instance]
  1. Go to the DB2 Agent directory to locate the Db2_config.sh utility.
  2. On the command line, type the following command.
    Db2_config.sh -d dbname -c client_name [-i Commvault_instance]
Example:
# su - db2inst1
 $ cd /opt/Commvault/iDataAgent
 $ ./Db2_config.sh -d testdb -i Instance001
 OPTIND is now 5
 DBNAME=testdb INSTANCE=Instance001
 Input:: DBNAME=testdb INSTANCE=Instance001
 set_db_params
 check_dir
 get_db2_paths
 /u01/database/db2/GDB2Archive
 /u01/database/db2/GDB2Audit
 /u01/database/db2/GDB2Retrieve
 /u01/database/db2/GDB2Archive is accessible
 /u01/database/db2/GDB2Retrieve is accessible
 /u01/database/db2/GDB2Audit is accessible
 get_base_dir
 Base directory: /opt/commvault/Base
 DB2 User:db2inst1
 DB2 Home: /home/db2inst1
 DB2SYSC Path: /home/db2inst1/sqllib/adm/db2sysc
 get_client_name
 Client Name=ggux18
 Executing:: db2 update db cfg for testdb using LOGARCHMETH1 VENDOR:/opt/Commvault/Base/libDb2Sbt.so
 DB20000I The UPDATE DATABASE CONFIGURATION command completed successfully.
 Executing:: db2 update db cfg for testdb using LOGARCHOPT1 CvClientName=ggux18,CvInstanceName=Instance001
 Executing:: db2 update db cfg for testdb using VENDOROPT CvClientName=ggux18,CvInstanceName=Instance001
 Executing:: db2 update db cfg for testdb using LOGARCHMETH2 OFF
 Executing:: db2 update db cfg for testdb using TRACKMOD ON
 <<<<<<<<<ENDED>>>>>>>>>
If you update the LOGARCHOPT1 parameters, you must restart the database after running this script.
