You can set options for the auto-mount process that runs when an auto-mounted NFS export subclient is backed up. The -o flag options are supported.
From the CommCell Browser, go to Client Computers > client > Linux File System > backup_set.
Double-click the subclient.
Click Advanced.
On the Auto Mount Options tab, in the Mount Options box, enter your
-oflag option.For example, if the auto-mount process should mount the NFS export as read-only, enter
ro.If you have multiple options, enter the options as a comma-separated list.
