Before you configure your storage array, verify that your system meets the following requirements.
Licenses
Install the following licenses.
Array |
Snapshot Type |
License |
HPE Nimble Storage/ Nimble dHCI/ HPE Alletra 5000 Series/ HPE Alletra 6000 Series |
Snapshot |
None |
Version and Firmware
Use the following version and firmware.
Important
Before you upgrade the HPE Nimble Storage firmware, move all snapshots to a secondary storage using the backup copy operation because array nodes will no longer be accessible using old interfaces.
Before you merge HPE Nimble Storage arrays to one group, move all snapshots to a secondary storage using the backup copy operation.
Array |
Version and Firmware |
HPE Nimble Storage/Nimble dHCI |
HPE Alletra 5000 Series |
Protocols
Use one of the following protocols.
Array |
Protocol |
HPE Nimble Storage/Nimble dHCI/HPE Alletra 5000 Series/ HPE Alletra 6000 Series |
Fibre Channel iSCSI |
Software
Install the following software.
Array |
Required Software |
None |
Ports
Open the following ports between the MediaAgent and the storage array:
SOAP - 5391
REST - 5392
