System Requirements for IBM Spectrum Scale (GPFS)
The following are the requirements for IBM Spectrum Scale (GPFS):
Application/Operating System
Architecture
GPFS 3.1 or higher on:
AIX
AIX 7.2 64-bit
Power PC
AIX 7.1 64-bit
Power PC
AIX 6.1 64-bit
Power PC
Linux
Red Hat Enterprise Linux/CentOS
Red Hat Enterprise Linux/CentOS 7.x with glibc 2.17.x
x86, x64, Power PC or compatible processors
SuSE Linux (SLES)
SuSE Linux 12.x with glibc 2.19.x
SuSE Linux 11.x with glibc 2.9.x and later
SuSE Linux 11.x with glibc 2.11.x
SuSE Linux 10.x with glibc 2.4.x
Hard Drive
1 GB of minimum disk space is required for installing the software.
To calculate the disk space requirements for the job results directory, see Job Results Directory Disk Space Calculation.
500 MB of free disk space is required for the log directory.
DISCLAIMER
Third-party maintenance (minor) releases or service packs that are supported by the Commvault software may not be listed in our System Requirements. When possible, Commvault provides information on any known issues related to these minor releases or service packs. In some cases, these minor releases or service packs affect how the Commvault software works. Commvault software may experience changes in functionality as the result of the third-party minor release or service pack. These changes are beyond the control of Commvault. Platforms that are supported in the current version of Commvault software may not be supported in earlier versions of the software. Contact your software provider to ensure that third-party minor releases or service packs are compatible with the Commvault software.
Additional considerations regarding minimum requirements and End-of-Life policies from third-party vendors also apply.
