Verify that your environment meets the system requirements for the Web Console and the Command Center. (The Web Console is installed as part of the Command Center package.)
Operating System
Important
Use the most recent version of the operating system that is listed. The Commvault software fully supports the most recent version of an operating system, until the vendor ends support. More recent versions of the Commvault software might not install on operating systems that are not supported by the vendor anymore. For information about the support lifecycle of an operating system, contact the vendor.
Linux
Operating system |
Processor architecture |
Red Hat Enterprise Linux 8.3 with glibc 2.28-108 |
x64 |
Red Hat Enterprise Linux 7.7 and above with glibc 2.17.x |
x64 |
Windows
Operating system |
Microsoft Windows Server 2022 Editions |
All Windows-compatible processors are supported |
Microsoft Windows Server 2019 Editions |
Microsoft Windows Server 2016 Editions |
Microsoft Windows Server 2012 Editions |
Microsoft Windows Server 2012 R2 Editions |
Hardware
Web Browser
Apple Safari (versions that are not older than a year)
Google Chrome (versions that are not older than a year)
Mozilla Firefox (versions that are not older than a year)
Microsoft Edge
Clustering
The software is supported on a cluster only when installed on a cluster that has the CommServe software. For more information on supported cluster types, see Support for Cluster Configuration.
Software That Is Automatically Installed
Tomcat Server
If the Apache Tomcat Server is not already installed, it is automatically installed with this software.
You cannot manually upgrade the Apache Tomcat Server. The Commvault software always updates the Tomcat server with the most recent security updates, so that the components that use the Tomcat server do not have vulnerabilities that are reported by the open source community.
Java SE Platform
Java is installed automatically during the installation of this software. If you already have a system-installed Java version, the software installs another instance of the supported Java version in the software installation path.
All Commvault binaries (JAR files) are signed by SHA-256 Digest. To verify that the downloaded JAR files from Java webstart/netx.jar are not modified, use SHA 256.
Commvault always updates the Java version with the most recent security updates, so that the components using Java do not have any vulnerabilities that are reported by the open source community. To manually upgrade the Java Runtime Environment (JRE) for the Commvault software, see KB article 57019.
File System Agent
If not already installed, the Windows File System Agent or Linux File System Agent is installed. For more information, see the following:
On Windows computers, to successfully restore NAS data and Domino emails on the web, install a 32-bit file system proxy instance on a 64-bit computer.
DISCLAIMER
