MySQL: System Requirements
Updated
Verify that your environment meets the system requirements for MySQL.
Application
MySQL Community Server, Percona Server, Enterprise, Standard, or Classic Edition 5.5.x, 5.6.x, 5.7.x, 8.0.x; MariaDB 5.5.x, 10.0.x to 10.6.x
Operating System
Important: Use the most recent version of the operating system that is listed. The Commvault software fully supports the most recent version of an operating system, until the vendor ends support. More recent versions of the Commvault software might not install on operating systems that are not supported by the vendor anymore. For information about the support lifecycle of an operating system, contact the vendor.
MySQL Community Server, Percona Server, Enterprise, Standard, or Classic Edition 8.0.x
Linux
Important:
  • If you have SELinux enabled on the client computer, create the SELinux policy module as a root user before performing a backup. The SELinux Development package must be installed on the client.
  • You can install a Percona server only on Linux operating systems.
Operating system
Processor architecture
Amazon Linux 2
  • x64
  • Compatible processors
Debian 11.x
  • x64
Debian 10.x
  • x64
Debian 9.x
  • x64
Red Hat Enterprise Linux/Oracle Linux Enterprise/CentOS 8.x
  • x86
  • x64
Red Hat Enterprise Linux/Oracle Linux Enterprise/CentOS 7.x with glibc 2.17.x
  • x86
  • x64
Red Hat Enterprise Linux/Oracle Linux Enterprise/CentOS 6.x with glibc 2.12.x
  • x86
  • x64
SuSE Linux 15.0
  • x64
SuSE Linux 12 Initial Release
  • x64
Ubuntu 14.04 LTS
  • x64
Ubuntu 16.04 LTS
  • x64
Ubuntu 18.04 LTS
  • x64
Ubuntu 20.04 LTS
  • x64
Windows
Operating system
Microsoft Windows Server 2019 Editions
All Windows-compatible processors are supported
Microsoft Windows Server 2016 Editions
Microsoft Windows Server 2012 Editions
Server Core installations are not supported.
Microsoft Windows Server 2008 R2 Editions
MySQL Community Server, Percona Server, Enterprise, Standard, or Classic Edition 5.5.x, 5.6.x, 5.7.x; MariaDB 5.5.x, 10.0.x to 10.6.x
FreeBSD
Operating system
FreeBSD 10.x
  • x64
FreeBSD 9.x
  • x64
HP-UX
Operating system
HP-UX 11i v3 (11.31)
Itanium
Linux
Important
  • On Ubuntu 9.x 64-bit computers, you must install the libstdc++.so.5 compatibility package. To install the package, use the following command:[root]# sudo apt-get install libstdc++5
  • On Ubuntu and Debian computers, install the latest packages for the operating system before installing the Agent. To install the latest packages, use the following command: [root]# apt-get upgrade
Operating system
Asianux 4
  • x64
Debian 11.x
  • x64
Debian 10.x
  • x64
Debian 9.x
  • x64
Debian 8.x
  • x64
Debian 7.x
  • x64
Debian 6.x with glibc 2.11.x
  • x64
Debian 5.x
  • x64
Gentoo release 10.1 with glibc 2.6.x
x64
  • x86
  • x64
  • x86
  • x64
  • x86
  • x64
Red Hat Enterprise Linux/Oracle Linux Enterprise/CentOS 5.x with glibc 2.5.x
  • x86
  • x64
Source Mage Linux
x64
SuSE Linux 12.0
  • x64
  • PowerPC (little endian)
SuSE Linux 11 (Initial Release/SP1 and later SPs) with glibc 2.9.x and higher
  • x64
Ubuntu 8.04
  • x64
Ubuntu 9.04
  • x64
Ubuntu 10.04 LTS
  • x64
Ubuntu 12.04 LTS
  • x64
Ubuntu 14.04 LTS
  • x64
Ubuntu 16.04 LTS
  • x64
Ubuntu 18.04 LTS
  • x64
Ubuntu 20.04 LTS
  • x64
Solaris
In a UNIX virtualization environment using Solaris, you can back up and restore data in both global and non-global zones.
Operating system
Solaris 11.x
  • x64
  • Sparc T/M series
Solaris 10 Update 6 or equivalent
  • x64
  • Sparc T/M series
Windows
Operating system
Hard Drive
Component
Space required
Software
1 GB
Job results folder
256 MB
Log folder
256 MB
Clustering
If clustering is supported by the operating system, you can install the software on a cluster. For information about supported cluster types, see Support for Cluster Configuration.
Block-Level Backups
  • Block-level backups are supported only on Linux platforms. For supported Linux kernel version details, see MySQL Block-Level Backup.
  • Block-level backups are not supported on the Network File System (NFS).
Software That Is Automatically Installed
File System Agent
Microsoft Visual C++ Redistributable 2017
Starting with Service Pack 18, Microsoft Visual C++ Redistributable 2017 (vcredist2017.exe) is automatically installed.
If a computer does not have the most recent Windows updates, the installation of Microsoft Visual C++ Redistributable 2017 will fail in installing Universal C Runtime. The following Windows updates must be installed to prevent the installation failure. The updates are not required on the most recent Windows operating system versions, such as Microsoft Windows 10 and Microsoft Windows Server 2016, because these versions have the Universal C Runtime already installed.
  • KB2919355
  • KB2939087
  • KB2975061
  • KB2999226
DISCLAIMER
