HyperScale X Reference Architecture nodes can be deployed in environments with tagged virtual LANs (VLANs) with bonding, and a separate management interface. (Management interface cannot be bonded.) Active-Backup and Link Aggregation Control Protocol (LACP) bonding modes are supported.
Use this procedure to deploy the HyperScale X Reference Architecture software using the Hyperscale ISO 3.2312 or higher version.
- Verify the requirements needed to setup the Bonded VLAN Topology With Management Network.
Keep the network names and IP addresses listed in the Network Requirements section of Bonded VLAN Topology With Management Network handy before you start the configuration. This will help you to accurately add the details during the deployment.
Log on to one of the nodes using the system console as described in Setting up the installation media. (Do not use PuTTy / SSH to setup the nodes.)
Launch the network configuration interface using the following command:
# hsxsetup
Configure the routable data protection VLAN interface (bonded) as follows:
Click Create bond.
From the Interfaces list, select the 2 interfaces that will form the data protection bond. (For example, enpsf3 and enpsf5)
From Bonding mode list, select either active-backup (Mode 1) or LACP (Mode 4).
Click CREATE.
Click Create VLAN.
The Create VLAN dialog box appears.
From the Interface list, click bond1.
In the VLAN ID box, enter the VLAN ID associated with the routable VLAN network and then click CREATE.
The bond1 interface appears with the VLAN ID in the Network Configuration page. (The VLAN ID will be different, depending on the VLAN ID in your environment.)
From the Network Type list, select CommServe Registration.
Add the IP Address and Netmask in the respective boxes.
Configure additional data protection VLAN interfaces (bonded) as follows:
(Repeat this step to add all the VLANs available in your environment.)
Click Create VLAN.
In the VLAN ID box, enter the VLAN ID associated with the additional data protection VLAN network.
Click CREATE.
The new bond1 interface appears with the VLAN ID in the Node and Network Configuration page.
From the Network Type list, select Data Protection.
Repeat this step to configure ALL the VLANs available in your environment.
Once completed your screen should be similar to the one shown in the following image: (The number of VLANs may vary depending on the number of VLANs available in your environment.)
Configure the storage pool interface (bonded) as follows:
Click Create bond.
From the Interfaces list, select the 2 interfaces that will form the storage pool bond. (For example, enpsf4 and enpsf6 .)
Click CREATE.
From the Network Type list, select Storage Pool. This interface will be be used exclusively for communication and replication between the HyperScale nodes.
Configure the management interface as follows:
Click Configure interface.
From the Interfaces list, select one of the management interfaces. (For example, enpsf1 or enpsf2.)
Click CREATE.
From the Network Type list, select Management. This interface will be used for all management related communication, such as connecting to the CommServe server, accessing the DNS server, etc.
Configure the DNS server(s) as follows:
In the Default Gateway box, add the IP address associated with the default gateway.
In the DNS Servers box, add the IP address associated with the DNS Server.
Click CONFIGURE.
Verify the network configuration and then click CONTINUE.
All the VLANs are included.
IP address and Netmask for the VLANs are accurate.
IP address and Netmask for the storage pool is accurate.
Hostname and serial number associated with the node is accurate.
Default gateway and DNS servers are accurately configured.
Click one of the following:
Click NO, EXIT to configure another node in the storage pool.
Click YES, CONTINUE if this is the last node in the storage pool.
The Setup Type page appears.
Click New storage pool setup and then click NEXT.
Select the nodes as follows:
Click the down arrow
at the top right area of the page to view a list of available nodes.
Click and select the nodes that must be included in the storage pool.
You can select up to 12 nodes at a time for the initial deployment. Nodes are listed by serial number. If one or more nodes are missing from the list, there is likely a cabling or network configuration issue. To troubleshoot, see Troubleshooting Network Configuration Errors.
Click NEXT.
Click NEXT.
Verify the summary for each node by clicking the tabs associated with each node. Ensure that the nodes are accurately configured and then click NEXT.
All nodes have the same number of VLANs.
All nodes have identical information for the VLANs.
All nodes have identical information for the default gateway and DNS servers.
Add the following information:
In the Root password and Confirm password boxes, type a secure password for the nodes.
In the Storage pool name box, type a name for the storage pool associated with the cluster.
From the Time zone list, select the time zone in which the nodes are located.
In the Password for Restricted shell user - cvbackupadmin and Confirm cvbckupadmin password boxes, type a secure password for the cvbackupadmin user.
Click NEXT.
Check the status to ensure that all the nodes are reachable. (All the nodes should have a green status.) Click NEXT.
The Deployment Information page appears.
Click Connect to existing CommServe, and then click NEXT.
The Credentials page appears.
Choose one of the following options to connect to the CommServe:
To connect using the user credentials, in the UserName and Password tab, provide the following details:
In the CommServe hostname (FQDN) box, enter a fully qualified host name of the existing CommServe server that you are connecting to.
In the Password box, enter the credentials that must be used to access the CommServe server and then click NEXT.
To connect using an authorization code, click Auth-Code, and then provide the following details. Make sure that you enable installation using authorization code for the CommCell. For more information, see Enabling Authorization Code
- In the CommServe hostname (FQDN) box, enter a fully qualified host name of the existing CommServe server that you are connecting to.
In the Auth-code box, enter the authorization code generated for the CommCell.
Click CLOSE.
What To Do Next
Complete the additional configurations that may be required to customize your environment. For more information, see What to do Next.
