Configuring Two-Way Connectivity between the CommServe Computer and the Client
If you plan to configure an environment in which the CommServe computer and the client can each initiate communications between each other (two-way network route), you can configure the client with the necessary network route settings during the installation of the Commvault software.
Follow the procedure that corresponds to one of the following installation methods:
