This operation creates a new folder in Edge Drive based on the GUID of the parent folder.
Request
Syntax
POST webservice/drive/file/folderId HTTP/1.1
Host: host name
Accept: application/xml | application/json
Authtoken: authentication token
Content-type: application/xml
<App_FileResourceInfo name=""/>
where <webservice> is the root path used to route the API requests to the Web Server.
For more information, see Available Web Services for REST API.
Request Parameters
Name |
Description |
Required |
folderId |
The GUID of the parent folder. GUID is a unique identifier for a file or folder and remains the same even when you rename or move the file or folder to another path. To retrieve the GUID of the parent folder, see View File or Folder Properties. |
Yes |
Request Headers
Name |
Description |
Host |
The host name of the Web Server or Web Console used in the API request. |
Accept |
The format of the response. Valid values are: application/xml or application/json. |
Authtoken |
The authentication token received after successfully logging on. For details on receiving an authentication token, see Authentication. |
Content-type |
The media type contained in the request body. |
Request Body
An XML element is required. See Syntax. The following table displays the parameters for the request body.
Name |
Description |
Elements |
name |
The name of the new folder. |
App_FileResourceInfo |
Response
Response Parameters
Parameter |
Description |
Element |
parentGuid |
The GUID of the parent folder. |
App_FileResourceResponse |
GUID |
The GUID of the new folder. |
directory |
directory=1 indicates the request item is a folder. |
path |
The path to the new folder. |
name |
Name of the new folder. |
Examples
Sample Request
POST webservice/drive/file/97409005317b4dbd9c138d2fd80a9e50 HTTP/1.1
Host: client.mydomain.com
Authtoken: QSDK 38568012f4d1e8ee1841d283a47aa3ba78e124ea58354b5fc60f4dab8a63347d05cf5552484dafda3bfa4c5db84e580b1cb37bcf8e65b39f7f8549a443e6f78a2c7be3f31b3d845e24776c835e498e8e883bb40c46bd15af4f40ca94e823acedcdd4e9659e74b34a07a85c4586cd2ed914b6dce015874783ef768fda78183a4208930954a377f66eb56c8b92cexampl4s437a19317ca6ce7f3233d5a01aca35dbad93468b833f2cf71010809006a937670adce711ca8be46638e8
<App_FileResourceInfo name="NewFolder"/>
Sample Response
<?xml version="1.0" encoding="UTF-8" standalone="no" ?>
<App_FileResourceResponse> <fileResource parentGuid="97409005317b4dbd9c138d2fd80a9e50" GUID="be7d714583584307bf00f1de47212b94" directory="1" name="NewFolder" path="\Folder1\NewFolder" />
</App_FileResourceResponse>
Supported Error Codes
Code |
Status |
Description |
400 |
Bad Request |
The request is missing required parameters or the folder name has some unacceptable characters. |
404 |
Not Found |
The specified parent folder does not exist. |
409 |
Conflict |
A folder with the specified name already exists in the same location. The response body will include the information of the folder that already exists. For example:
