From backups performed with the Virtual Server Agent, you can perform a full VM restore and convert the source virtual machine to be used with a different hypervisor.
You can perform conversions from streaming backups, from secondary copies, or, for hypervisors that support IntelliSnap, from IntelliSnap backup copies. You can't perform a conversion from a Snap copy.
The following table shows the cross-hypervisor restores that are supported by Commvault.
| DESTINATION | Alibaba Cloud ECS | Amazon EC2 | Azure | Azure Stack Hub | Azure Local | Google Cloud Platform | Hyper-V | Nutanix AHV | OpenStack | Oracle VM | Oracle Cloud Infrastructure | Red Hat Virtualization | VMware | VMware Cloud Director |
| SOURCE | ||||||||||||||
| Amazon EC2 | -- | -- | Yes | -- | -- | Yes | -- | -- | -- | -- | -- | -- | Yes | -- |
| Azure | -- | Yes | -- | Yes | Yes | Yes | Yes | -- | -- | -- | -- | -- | Yes | -- |
| Azure Stack Hub | -- | -- | Yes | -- | -- | -- | -- | -- | -- | -- | -- | -- | -- | -- |
| Azure Local | -- | Yes | Yes | Yes | -- | -- | Yes | -- | -- | -- | -- | -- | Yes | -- |
| Google Cloud Platform | -- | -- | -- | -- | -- | -- | -- | -- | -- | -- | -- | -- | Yes | -- |
| Hyper-V | -- | Yes | Yes | Yes | Yes | -- | -- | -- | -- | -- | -- | -- | Yes | -- |
| Nutanix AHV | -- | -- | Yes | -- | -- | -- | -- | -- | -- | -- | -- | -- | Yes | -- |
| Oracle VM | -- | -- | Yes | -- | -- | -- | -- | -- | -- | -- | -- | Yes | -- | -- |
| VMware | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | -- | -- | -- |
| VMware Cloud Director | -- | -- | -- | -- | -- | -- | -- | -- | -- | -- | -- | -- | Yes | -- |
