Deprecation Notice for Two-Way Sync Using the ContinuousDataReplicator Agent
The Two-Way Sync feature using the ContinuousDataReplicator Agent is deprecated in this version of the software. For more information about the Obsolescence Policy, see End-of-Life, Deprecated, and Extended Support - Obsolescence Policy.
Effective Release
Version 11, Feature Release 19
Effect of Deprecation
Existing two-way sync configurations using the ContinuousDataReplicator Agent will continue to function as defined. However, new two-way sync configurations using the ContinuousDataReplicator Agent are not supported.
Replacement
For similar functionality, use Live Sync Replication.
