You can set up direct connection routes by using the basic or advanced network settings that are available in the network properties of the client computer. The basic configuration is only available for one-way direct connection (client to CommServe).
Based on your environment, select the type of direct connection that you want to configure between the client and CommServe computer:
One-way direct connection (client to CommServe)
If you plan to set up direct connections between client groups, consider using network topologies.
