Verify that your environment meets the system requirements for Compliance and eDiscovery.
Commvault Packages
To use Data Insights for Compliance and eDiscovery, install the following packages on a computer.
Index Store
Exchange Mailbox Agent
Operating System
The computer that you install the required Commvault packages on must use one of the following operating systems.
Windows
Windows Server 2022 Editions
Windows Server 2019 Editions
Windows Server 2016 x64 Editions
For additional system requirements for the Exchange Mailbox Agent, see Exchange Mailbox Agent: System Requirements.
File Data
Content indexing file system data from backups |
Large |
Medium |
Small |
Source data size per node Based on the following assumptions:
160 TB |
80 TB |
40 TB |
Objects per node (estimated) |
30 million |
15 million |
7.5 million |
CPU or vCPU |
32 cores |
16 cores |
8 cores |
RAM |
64 GB |
32 GB |
16 GB |
Disk space |
12 TB |
6 TB |
3 TB |
To get higher scalability for content indexing files from backups, you can turn off the generate previews option on the Search Engine node. When generate previews is off, each search node can accommodate approximately twice the number of objects per node. For example, in a large enterprise, this would be approximately 40 TB of source data (about 60 million objects), and the required disk space is 15% of source data (up to 6 TB).
Email Messages
Component |
Large |
Medium |
Small |
Source application size |
25 TB |
15 TB |
5 TB |
Objects per node (an estimate based on an average message size of 100 KB. Messages with attachments are considered a single object) |
250 million |
150 million |
50 million |
Number of mailboxes (based on an average mailbox size of 5 GB, and an average of 50,000 messages per mailbox) |
5000 |
2000 |
400 |
CPU |
16 cores |
16 cores |
8 cores |
RAM |
64 GB |
32 GB |
16 GB |
Index disk space (SSD class disk recommended) |
10 TB |
6 TB |
2 TB |
