Verify that your environment meets the system requirements for Index Gateway.
Operating System
Important
Use the most recent version of the operating system that is listed. The Commvault software fully supports the most recent version of an operating system, until the vendor ends support. More recent versions of the Commvault software might not install on operating systems that are not supported by the vendor anymore. For information about the support lifecycle of an operating system, contact the vendor.
Linux
Operating system |
Processor architecture |
Red Hat Enterprise Linux 8.2 through 9.5 |
x64 |
Rocky Linux 8.9 through 9.5 |
x64 |
Windows
Operating system |
Windows Server 2019 Editions |
All Windows-compatible processors are supported |
Windows Server 2016 Editions |
Hard Drive
Component |
Space required |
Temp folder |
20 GB |
Internet Information Services
To install this software, Microsoft Internet Information Services (IIS) must be enabled on the computer and meet the following requirements:
Internet Information Services Manager version 10.0 (on Windows 2016 only)
Internet Information Services Manager version 8.0 or 8.5 (on Windows 2012 only)
Software That Is Automatically Installed
.NET Core
.NET Core 10.0.8 is required and is automatically installed.
DISCLAIMER
