Running Operations Using CvSQLBackupUtility Tool
You can run the following operations using the CvSQLBackupUtility tool:
Connecting to a specific instance
On the command line, run the following operation after substituting the parameter values:
CvSQLBackupUtility.exe /operation Connect /instance instance_name
For example:
CvSQLBackupUtility.exe /operation Connect /instance Server1\Instance1 /user User1 /password Password1
For detailed information about parameters, see Available Parameters for CvSQLBackupUtility Tool.
Discovering instances
CvSQLBackupUtility.exe /operation DiscoverInstances
For example:
CvSQLBackupUtility.exe /operation DiscoverInstances /quiet /logfile “mylog.txt”
Discovering databases
CvSQLBackupUtility.exe /operation DiscoverDatabases /instance instance_name
For example:
CvSQLBackupUtility.exe /operation DiscoverDatabases /instance Server1\Instance1 /user User1 /password Password1
Getting backup information for a specific backupset
CvSQLBackupUtility.exe /operation GetBackupInfo /backupsetid backupsetID_name
For example:
CvSQLBackupUtility.exe /operation GetBackupInfo /backupsetid 1234
Getting backup information for a specific database
CvSQLBackupUtility.exe /operation GetDatabaseBackupInfo /instance instance_name /database database_name
For example:
CvSQLBackupUtility.exe /operation GetDatabaseBackupInfo /instance Server1\Instance1 /database DB1 /user User1 /password Password1
Getting raw files for a specific database
CvSQLBackupUtility.exe /operation GetNewFiles /instance instance_name /database database_name /backupsetid backupsetID_name
For example:
CvSQLBackupUtility.exe /operation GetNewFiles /instance Server1\Instance1 /database DB1 /backupsetid 1234 /user User1 /password Password1
Getting full-text catalogs for a specific database
CvSQLBackupUtility.exe /operation GetNewFullTextCatalogs /instance instance_name /database database_name /backupsetid backupsetID_name
For example:
CvSQLBackupUtility.exe /operation GetNewFullTextCatalogs /instance Server1\Instance1 /database DB1 /backupsetid 1234 /user User1 /password Password1
Getting recovery model for a specific database
CvSQLBackupUtility.exe /operation GetRecoveryModel /instance instance_name /database database_name
For example:
CvSQLBackupUtility.exe /operation GetRecoveryModel /instance Server1\Instance1 /database DB1 /user User1 /password Password1
Getting restore information for a specific backupset
CvSQLBackupUtility.exe /operation GetRestoreInfo /backupsetid backupsetID_name
For example:
CvSQLBackupUtility.exe /operation GetRestoreInfo /backupsetid 1234
Getting restore information for a specific database
CvSQLBackupUtility.exe /operation GetDatabaseRestoreInfo /instance instance_name /database database_name
For example:
CvSQLBackupUtility.exe /operation GetDatabaseRestoreInfo /instance Server1\Instance1 /database DB1 /user User1 /password Password1
Getting the server version for a specific instance
CvSQLBackupUtility.exe /operation GetServerVersion /instance instance_name
For example:
CvSQLBackupUtility.exe /operation GetServerVersion /instance Server1\Instance1 /user User1 /password Password1
Getting status of a specific database
CvSQLBackupUtility.exe /operation GetStatus /instance instance_name /database database_name
For example:
CvSQLBackupUtility.exe /operation GetStatus /instance Server1\Instance1 /database DB1 /user User1 /password Password1
Truncate logs of a specific database
CvSQLBackupUtility.exe /operation TruncateLog /instance instance_name /database database_name
For example:
CvSQLBackupUtility.exe /operation TruncateLog /instance Server1\Instance1 /database DB1 /user User1 /password Password1
Running a backup operation
CvSQLBackupUtility.exe /operation Backup /instance instance_name /database database_name /backupfile backupfile_name
For example:
CvSQLBackupUtility.exe /operation Backup /instance Server1\Instance1 /database DB1 /user User1 /password Password1 /backupfile “C:\MyBackups\MyDB.bkp” /devicecount 2 /blocksize 8192 /buffercount 4 /maxtransfersize 131072 /vditimeout 420
Running a restore operation
CvSQLBackupUtility.exe /operation Restore /instance instance_name /database database_name /backupfile backupfile_name
For example:
CvSQLBackupUtility.exe /operation Restore /instance Server1\Instance1 /database DB1 /user User1 /password Password1 /backupfile “C:\MyBackups\MyDB.bkp” /devicecount 1 /blocksize 8192 /buffercount 4 /maxtransfersize 131072 /vditimeout 420
Restoring database to a different location
CvSQLBackupUtility.exe /operation Restore /instance instance_name /database database_name /backupfile backupfile_name /renameparams “MOVE File1 TO Location1, MOVE File2 TO Location2
For example:
CvSQLBackupUtility.exe /operation Restore /instance Server1\Instance1 /database DB1 /user User1 /password Password1 /backupfile “C:\MyBackups\MyDB.bkp” /renameparams “MOVE ‘MyDB’ TO ‘C:\ExistingDir\MyDB.mdf’, MOVE ‘MyDB_Log’ TO ‘C:\ExistingDir\MyDB.ldf’
Running a query operation
CvSQLBackupUtility.exe /operation PerformQuery /instance instance_name /database database_name /query T-SQL_command
For example:
CvSQLBackupUtility.exe /operation Backup /instance Server1\Instance1 /database DB1 /query “CREATE TABLE NewTable (Field1 varchar(256), Field2 int)”
Displaying help for CvSQLBackupUtility
CvSQLBackupUtility.exe /help
