Before you configure your storage array, verify that your system meets the following requirements.
Licenses
Install the following licenses.
Array |
Snapshot Type |
License |
HPE EVA |
EVA Business Copy Snapshot |
HPE Business Copy EVA |
EVA Business Copy Clone |
Version and Firmware
Ensure that you are using compatible versions and firmware.
Array |
Version and Firmware |
HPE EVA |
EVA HPE EVA 10.3 |
Protocols
Ensure that at least one of the following protocols is available:
Array |
Protocol |
HPE EVA |
Fibre Channel iSCSI |
Software
Install the following software components:
Array |
Required Software |
HPE EVA |
HPE SMI-S EVA on the server Command View Version 9.3 or 9.1 |
Ports
For snap-based operations, open port 5989 for HTTPS and port 5988 for HTTP between the CommServe computer or MediaAgent and the storage array.
