System Requirements for the Huawei Storage Array
Before you configure the storage array, verify that your environment meets the system requirements.
Encryption Algorithm
The Commvault software uses libssh version 2-1.6.0 with the following algorithms:
  • hmac_sha1
  • hmac_md5
  • hmac_md5_96
  • hmac_ripemd160
  • hmac_ripemd160_openssh_com
Licenses
Install the following licenses.
Snapshot Type
License
Snapshot
HyperSnap
Clone
  • HyperClone
  • Smart Thin (optional for Thin Clone)
Version and Firmware
Use the following version and firmware.
Array
Huawei OceanStor Convergent Series
  • Huawei OceanStor V3 Convergent Storage
    V300R006C50, V300R006C30, V300R006C20, V300R006C10
    vStore is supported from V300R006C10 and later versions.
  • Huawei OceanStor V5 Convergent Storage V500R007
  • Huawei OceanStor Hybrid Flash Storage 6.1
Huawei OceanStor Dorado Series
  • Huawei OceanStor Dorado V3-V300R001C00
    Clone engine is not supported.
    User created vStores are not supported.
  • Huawei OceanStor Dorado V6 – 6.1
Protocols
Use one of the following protocols.
Array
Protocols
  • CIFS, NFS. Support for the CIFS protocol and the NFS protocol is for network share backups only and with the Huawei OceanStor V3 models with version V300R006C10 or later versions.
  • Fibre Channel
  • iSCSI
  • Fibre Channel
  • iSCSI
  • CIFS and NFS. Support for these protocols is for network share backups only with V6 models.
Ports
Operations
Port to Open
Snapshot on vStores or on the physical array
22 (SSH) and 8088, between the CommServe computer, client, Proxy MediaAgent and the Huawei storage array.
