Before you configure your storage array, verify that your environment meets the following requirements.
Licenses
Install the following licenses.
Snapshot Type |
License |
Snapshot |
VolumeCopy |
PiT (Point-in-Time) |
Versions and Firmware
Use the following version and firmware.
Array |
Version and Firmware |
NetApp E-Series/LSI |
Protocols
Use one of the following protocols.
Array |
Protocol |
Software
Install the following software.
The VolumeCopy engine does not work the SMI-S provider with firmware versions 11.52, 11.42, and 11.40. If you use the VolumeCopy engine with the SMI-S provider 11.52, 11.42, or 11.40, creating the volume copy relationship fails and it might also bring the SMI-S provider services down.
Array |
Required Software |
LSI SMI-S server versions:
Ports
For snapshot operations, open ports 5989 (HTTPS) and 5988 (HTTP) between the server computers, Proxy MediaAgents, and client computers.
