Setting up a Static IP For Intelligent Platform Management Interface (IPMI)
Updated
Setup a static IP for the Intelligent Platform Management Interface (IPMI) port on all the nodes. This is needed to setup the HyperScale X Appliance. In addition, this will also ensure that the IPMI is accessible in the network using the static IP for lights out access. For example, it would be useful to power-on or power-off the nodes using the IPMI console.
Review the following requirements:
  • Connect the IPMI (or BMC Controller) port to the IPMI network.
    Click here to view the IPMI port for HS2300
    Cabling HyperScale X Appliance for Redundant Networking (13)
    Click here to view the IPMI port for HS4300
    Cabling HyperScale X Appliance for Redundant Networking (14)
  • Connect a VGA monitor and USB keyboard, or the KVM connection, to the appliance.
  1. Power on the node.
  2. Press <DEL> during the boot splash screen. The Setup Utility will be displayed.
    Setting up a Static IP For IPMI (1)
  3. Navigate to the IPMI tab.
    Setting up a Static IP For IPMI (3)
  4. Navigate to the BMC Network Configuration option.
    Press <Enter> to select the option.
  5. Set Update IPMI LAN Configuration to [Yes].
  6. Set Configuration Address Source to [Static].
    Setting up a Static IP For IPMI (2)
  7. Enter values for the Station IP Address, Subnet Mask, and Gateway Address for the selected node.
  8. Press <F4> to save and exit the Setup Utility.
  9. Verify that the IPMI is accessible using the static IP address as follows:
    1. Open a web browser from a remote workstation and enter the static IP of the IPMI.
    2. The login screen will be displayed.
      Setting up a Static IP For IPMI (4)
    3. Type in the credentials for the default administrator account as follows:
      Username: ADMIN
      Password: ADMIN
      The IPMI password can be changed later from the IPMI Web Server interface. For more information, see Changing the IPMI Password on HyperScale X Appliance Nodes.
    4. Click Login.
      The IPMI Web Server interface is displayed.
      Setting up a Static IP For IPMI (5)
  10. Launch the Remote Console window as follows:
    1. Click inside the Remote Console preview.
      This will launch a Java Applet.
    2. Run the Java applet to start the Remote Console Window.
      Alternatively, if you do not want to use Java Applet, you can use HTML5 viewer. Click Remote Control > iKVM/HTML5 and then click the iKVM/HTML5 button.
      Setting up a Static IP For IPMI (6)
      The Remote Console window will be displayed.
      Setting up a Static IP For IPMI (7)
  11. Login using the following default credentials:
    Login:root
    Password:cvadmin
    If the login prompt is not displayed, press <Alt> + <F2> or <++> keys to display the prompt.
    This password can be changed during setup.
    Note down the Hostname, which is also the unique serial number for the specific node. This hostname/serial number will be useful to identify the node when you deploy the HyperScale X Appliance software.
Was this page helpful?
