Cross-Hypervisor Restores (Virtual Machine Conversion)
From backups performed with the Virtual Server Agent, you can perform a full VM restore and convert the source virtual machine to be used with a different hypervisor.
You can perform conversions from streaming backups, from secondary copies, or, for hypervisors that support IntelliSnap, from IntelliSnap backup copies. You can't perform a conversion from a Snap copy.
The following table shows the cross-hypervisor restores that are supported by Commvault.
DESTINATION Alibaba Cloud ECS Amazon EC2 Azure Azure Stack Hub Azure Local Google Cloud Platform Hyper-V Nutanix AHV OpenStack Oracle VM Oracle Cloud Infrastructure Red Hat Virtualization VMware VMware Cloud Director
SOURCE
Amazon EC2 -- -- Yes -- -- Yes -- -- -- -- -- -- Yes --
Azure -- Yes -- Yes Yes Yes Yes -- -- -- -- -- Yes --
Azure Stack Hub -- -- Yes -- -- -- -- -- -- -- -- -- -- --
Azure Local -- Yes Yes Yes -- -- Yes -- -- -- -- -- Yes --
Google Cloud Platform -- -- -- -- -- -- -- -- -- -- -- -- Yes --
Hyper-V -- Yes Yes Yes Yes -- -- -- -- -- -- -- Yes --
Nutanix AHV -- -- Yes -- -- -- -- -- -- -- -- -- Yes --
Oracle VM -- -- Yes -- -- -- -- -- -- -- -- Yes -- --
VMware Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes -- -- --
VMware Cloud Director -- -- -- -- -- -- -- -- -- -- -- -- Yes --
