The Virtual Server Agent can be installed on one or more machines, so that those machines can serve as VSA proxies. A VSA proxy manages backup and restore operations for guest VMs in your environment, eliminating the need to install agents on guest VMs.
Verify that your environment meets the requirements for protecting Huawei FusionCompute VMs with Commvault.
Supported FusionCompute Versions
FusionCompute 8.7.x, 8.6.x, 8.5.x, 8.1.x, 8.0.x, 6.5.x, 6.3.x
FusionCompute 8.0.x + FusionStorage 8.0.1.5 (VM storage provisioned on FusionStorage other than SAN/NAS storage). Huawei also packaged this combination as FusionCube 6.0.1 SPC100
FusionCompute 6.5.1 + FusionStorage 6.3 (VM storage provisioned on FusionStorage other than SAN/NAS storage). Huawei also packaged this combination as FusionCube 3.2.1
FusionCompute 6.3.1 + FusionStorage 6.2 SPC200 (VM storage provisioned on FusionStorage other than SAN/NAS storage). Huawei also packaged this combination as FusionCube 3.1.1 SPC100.
Huawei deprecated support for SAN transport mode after the 5.x release of FusionCompute.
Support for FusionStorage
You can deploy Commvault to protect FusionCompute workloads that run as part of a hyper-converged solution on FusionStorage. See Support for FusionStorage.
Supported Operating Systems for Access Nodes
Linux
RHEL 8, 7.5, 7, 6.x
For a machine that runs RHEL 8.x or 9.x, to install operating system packages that are required to enable automatic installation of Mono, register the machine with Red Hat.
When using FusionStorage 6.2, RHEL 7.3 or a more recent version is recommended.
For Linux access nodes, disable automatic activation of volumes to avoid issues with HotAdd operations during backup and recovery. For more information, see Disabling Automatic Activation of Volumes for a Linux Proxy.
Windows
Microsoft Windows Server 2025 x64 Editions (Standard, DataCenter, and Core)
Microsoft Windows Server 2022 x64 Editions (Standard, DataCenter, and Core)
Microsoft Windows Server 2019 (Standard, Datacenter) (64-bit only) x64 Editions (Standard, DataCenter, and Core)
Microsoft Windows Server 2016 x64 Editions (Standard, DataCenter, and Core)
Support for Storage Infrastructure
Storage infrastructure can include local disks, NFS, iSCSI, or Fibre Channel.
Port Requirements
When the FusionCompute environment includes a firewall, verify that CVD port 8400 is configured to accept incoming traffic from Commvault.
Open port 7443 on the FusionCompute Virtual Resource Manager (VRM).
Open port 35001 on Compute Node Agent (CNA) hosts.
Hardware Requirements
See Hardware Specifications for Virtual Server Agent.
DISCLAIMER
