You can add an additional mount paths to an existing Air Gap Protect library.
From the CommCell Browser, expand Storage Resources > Libraries.
Right-click the appropriate library, and then click Add Mount Path. The Add Mount Path dialog box appears.
In the General tab, select the following: -
From the MediaAgent list, select the MediaAgent that must be used to access the library.
From the Location list, select a Air Gap Protect location. Note Recommended: Choose a location nearest to the MediaAgent.
The new mount path is added to the Air Gap Protect library.
