For IntelliSnap backups from Commvault software, add the Dell EMC Isilon/PowerScale storage array and its configuration information to the CommServe database.
Verify that the user account used to access the Dell EMC Isilon/PowerScale storage array has the privileges needed for the operations that you require.
| Operation | Privileges |
| IntelliSnap backups |
| Offline replication using Isilon SyncIQ technology | SyncIQ > Configure SyncIQ > Read/Write |
| Changelist | Job Engine > Schedule cluster wide jobs |
| Browsing subclient content for NDMP |
On the ribbon in the CommCell Console, click the Storage tab, and then click Array Management. The Array Management dialog box appears.
Click Add. The Array Properties dialog box appears.
On the General tab, specify the following information: -
From the Snap Vendor list, select Dell EMC Isilon/PowerScale.
In the Name box, enter the external IP address or the host name of any node in the Isilon cluster.
In the Control Host box, enter the external IP address or the host name of any node in the Isilon cluster.
In the Credentials area, click Change. The Enter the User Name and Password dialog box appears.
Type the credentials of a user who has the privileges needed for the operations that you require.
To configure additional MediaAgents to perform operations on the storage array, click the Array Access Nodes tab, and then select configuration options. For more information, see Configuring Array Access nodes.
On the Snap Configuration tab, configure Snapshot Configuration Properties according to your needs.
