If you want to perform block-level backup operations on a SQL database, then you must select the Optimize for table level restore check box at the subclient level.
From the CommCell Console, click Client Computers > client > SQL Server > instance.
Right-click a subclient for which you want to enable block-level backup operations, and then click Properties. The Subclient Properties dialog box appears.
On the Advanced Options tab, select the Optimize for table level restore check box. A message appears that tells you that the next backup will be converted to a full backup.
Click OK to close the message.
