You can configure clients or client groups to connect to the CommServe computer and MediaAgent through a network gateway.
If you do not want to use network topologies to configure your network gateway connection routes, you can use the Advanced network settings.
The advanced configuration includes additional configuration steps, and is recommended for more experienced users. For example, you can configure incoming connection restrictions and ports.
Process Flow
Install the Commvault software on one or more clients. During client installation, configure the client to connect to the CommServe computer through a network gateway. For network settings instructions during the installation, see Setting Up Connectivity to the CommServe Computer Using a Network Gateway.
Set up network routes to establish connections from the client (or client group) to the CommServe computer and MediaAgent. For instructions, see Configuring the Client for Network Gateway Connections.
Set up network routes between the CommServe computer and the client (or client group) through the Commvault network gateway. For instructions, see Configuring the CommServe Computer for Network Gateway Connections.
Set up network routes between the MediaAgent and the client (or client group) through the Commvault network gateway. For instructions, see Configuring the MediaAgent for Network Gateway Connections.
