The following table displays all the parameters you can use with the commands.
| Element | Description | Parent Element |
| switchIfOffline | To use an alternate data path when resources are offline. | copyFlags |
| switchIfBusy | To use an alternate data path when resources are busy. | copyFlags |
| roundRobbinDataPath | Enable to automatically load balance between all the available data paths. If the client and MediaAgent are on the same computer, you can perform LAN free operations. In such scenario, you must set all the following parameters to 0:
 | copyFlags |
| hours/minutes | You can use alternate data path when resources in default data path are busy. Specify the time period (hours and minutes) for which you want to wait before using the alternate data path. | resourcesOfflineWaitTimeInHoursMinutes |
| hours/minutes | You can use alternate data path when resources in default data path are offline. Specify the time period (hours and minutes) for which you want to wait before using the alternate data path. | resourcesBusyWaitTimeInHoursMinutes |
Download the Update_DataPathConfig.xml file and save it on the computer from where the command will be executed.
Execute the following command from the <software_installation_directory>/Base folder after substituting the parameter values. Example -
To use an alternate data path for a copy Copy1, immediately when the resources are busy. qoperation execute -af download location\Update_DataPathConfig.xml -copyName Copy1 -storagePolicyName SP01 -switchIfBusy 1 -resourcesBusyWaitTimeInHoursMinutes/hours 0 resourcesBusyWaitTimeInHoursMinutes/minutes 0If you want to wait for two hours when the resources are busy and then use an alternate data path for a copy Copy1. qoperation execute -af download location\Update_DataPathConfig.xml -copyName Copy1 -storagePolicyName SP01 -switchIfBusy 1 -resourcesBusyWaitTimeInHoursMinutes/hours 2 resourcesBusyWaitTimeInHoursMinutes/minutes 0
To use an alternate data path for a copy Copy1, immediately when the resources are offline. qoperation execute -af download location\Update_DataPathConfig.xml -copyName Copy1 -storagePolicyName SP01 -switchIfOffline 1 -resourcesOfflineWaitTimeInHoursMinutes/hours 0 resourcesOfflineWaitTimeInHoursMinutes/minutes 0If you want to wait for two hours when the resources are busy and then use an alternate data path for a copy Copy1. qoperation execute -af download location\Update_DataPathConfig.xml -copyName Copy1 -storagePolicyName SP01 -switchIfOffline 1 -resourcesOfflineWaitTimeInHoursMinutes/hours 2 resourcesOfflineWaitTimeInHoursMinutes/minutes 0
To automatically load balance between all the available data paths for a copy Copy1. qoperation execute -af download location\Update_DataPathConfig.xml -copyName Copy1 -storagePolicyName SP01 -roundRobbinDataPath 1To perform auxiliary copy operation using the LAN free data path, execute the following command: qoperation execute -af download location\Update_DataPathConfig.xml -copyName Copy1 -storagePolicyName SP01 -roundRobbinDataPath 0 -switchIfOffline 0 -switchIfBusy 0
