Before you configure your storage virtual machine, verify that your system meets the following requirements.
Version and Firmware
Use the following version and firmware.
| Product | Version and Firmware |
| Amazon FSx for NetApp ONTAP | ONTAP 9.16.1, 9.15.1, 9.14.1, 9.13.1, 9.12.1, 9.11.1 |
| Open Replication | ONTAP 9.16.1, 9.15.1, 9.14.1, 9.13.1, 9.12.1, 9.11.1 |
Protocols
Use one of the following protocols.
| Array | Protocol |
| NetApp |
| NetApp with Open Replication |
Ports
For snap-based operations, open port 443 (HTTPS) for communication between the NetApp server and CommServe computer, MediaAgent, access node or Remote Snap MediaAgent in your CommCell environment.
