Before you configure the storage array, verify that your environment meets the system requirements.
Licenses
Install the following licenses.
| Array | Snapshot Type | License |
| Hitachi Vantara VSP using CCI Engine | ShadowImage | ShadowImage |
| Thin Image | Thin Image | |
| Hitachi Targetless Snap (CCI) Engine | Thin Image | Thin Image |
Version and Firmware
Use the following version and firmware.
| Array | Version and Firmware |
*Supported through Field Certification. Contact your Software Provider or Professional Services to see if the specific FCoE can be supported.
Support for HTI and HTIA Snapshots
| Array | VSP 5000 | VSP E Series | VSP F/G Series | VSP One Block |
| HTI | Yes | Yes | Yes | No |
| HTIA | Yes | Yes | No | Yes |
Protocols
Use one of the following protocols.
| Array | Protocol |
Software
Install the following software.
| Array | Required Software |
| Hitachi Vantara VSM or GAD |
| Remote Snap MediaAgent |
Ports
You do not need to open any specific port.
