Before you configure your storage array, verify that your system meets the following requirements.
Licenses
Install the following licenses.
| Array | Snapshot Type | License |
| HPE EVA | EVA Business Copy Snapshot | HPE Business Copy EVA |
| EVA Business Copy Clone | HPE Business Copy EVA |
Version and Firmware
Ensure that you are using compatible versions and firmware.
| Array | Version and Firmware |
| HPE EVA | EVA HPE EVA 10.3 |
Protocols
Ensure that at least one of the following protocols is available:
| Array | Protocol |
| HPE EVA | Fibre Channel iSCSI |
Software
Install the following software components:
| Array | Required Software |
| HPE EVA | HPE SMI-S EVA on the server Command View Version 9.3 or 9.1 |
Ports
For snap-based operations, open port 5989 for HTTPS and port 5988 for HTTP between the CommServe computer or MediaAgent and the storage array.
