Before you configure the storage array, verify that your environment meets the system requirements.
Encryption Algorithm
The Commvault software uses libssh version 2-1.6.0 with the following algorithms:
hmac_sha1
hmac_md5
hmac_md5_96
hmac_ripemd160
hmac_ripemd160_openssh_com
Licenses
Install the following licenses.
| Snapshot Type | License |
| Snapshot | HyperSnap |
| Clone |
Version and Firmware
Use the following version and firmware.
| Array | Version and Firmware |
| Huawei OceanStor Convergent Series |
| Huawei OceanStor Dorado Series |
Protocols
Use one of the following protocols.
| Array | Protocols |
Ports
| Operations | Port to Open |
| Snapshot on vStores or on the physical array | 22 (SSH) and 8088, between the CommServe computer, client, Proxy MediaAgent and the Huawei storage array. |
