System Requirements for MongoDB
Verify that your environment meets the system requirements.
All Environments
  • All mongod and mongos instances must run with configuration files in the YAML format.
  • If the ports between the master node and the other cluster nodes are blocked, the nodes must connect through a firewall.
  • If the client name and the MongoDB host name differ, then the MongoDB host name must resolve to an IP address that is accessible by Commvault and is included in the MongoDB bind_ip setting.
  • The security.keyFile parameter value must be identical across cluster nodes.
  • Store the authentication security key file, encryption key files, and TLS configuration files in a separate directory other than the MongoDB data directory.
Linux Environments
  • Database authentication is supported on both Windows and Linux for full backups. For incremental backups, authentication is supported only on Linux.
  • For MongoDB deployments with authentication enabled, use a database user with one of the role configurations:
    • root role on the admin database (superuser)
    • backup, restore, and clusterAdmin roles on the admin database as an alternative to the root role.
  • Logical Volume Manager (LVM) volume groups must have enough free space to create IntelliSnap snapshots. By default, the copy-on-write (COW) cache size is 4096 MB or 10% of the volume size, whichever is greater. You can increase the COW cache size if needed.
    • As a best practice, keep at least 10% free space in the volume group. This free space is typically sufficient for environments with low to moderate write activity. If your workload changes data frequently, you may need more free space to prevent the snapshot from becoming invalid.
    • For native LVM snapshots, the event_activation setting in the /etc/lvm/lvm.conf file can be set to either 0 or 1. Both settings are supported.
    • When you set event_activation=0, configure auto_activation_volume_list to include all LVM logical volumes that are required for the operating system to boot, including the applicable boot and system logical volumes.
      For LVM snapshots, set the snapshot retention for the LVM snapshot copy to 0 days in the backup plan associated with the MongoDB cluster.
Protect Encrypted Database
Commvault protects MongoDB replica set and sharded clusters that use encrypted databases. MongoDB clusters must use a local master encryption key file on all nodes to encrypt databases. During discovery or a full backup, the software backs up the key file from the source master node.
All nodes of the cluster must have the same key file contents.
  • For encrypted database restores, the Commvault software performs the following actions:
    • In-place restore
      • Restores the key file to its original location.
      • Automatically renames the existing key file.
    • Out-of-place restore
      • Restores the key file to all destination clients.
      • Creates the key file path if it does not exist.
    • Granular restore
      • Creates the key file on the 3DFS share that is used to start the staging server.
  • Enable encryption on the destination clients only when restoring from an encrypted backup.
The Encryption at rest support feature that is enabled by bMongoDbEnableBkpEncryptionKey is only supported for replica set clusters.
Sharded Cluster Environments
  • Create the same database user on all shard servers and the config server.
  • Each sharded server must be a replica set, and the replica set must have at least one secondary node.
  • The Commvault software is not required on the arbiter nodes. No client is associated with the arbiter during node discovery, and this does not impact backup or restore operations.
    If the MongoDB cluster includes an arbiter node, do the following steps for an in-place or out-of-place restore:
    1. Before initiating the restore, manually stop the MongoDB service on the arbiter node and clean up the applicable data directories.
    2. Perform the required in-place or out-of-place restore.
    3. After the restore is complete, verify the cluster configuration and confirm that the arbiter node role is automatically added by the restore process. Then, start the MongoDB service on the arbiter node.
Job Results Directory Space Requirements
For incremental backups, the software creates oplog dump files every 15 minutes in the job results directory.
Ensure that the job results directory has sufficient free space to accommodate the cumulative size of the oplog dump files that are generated until the next incremental backup.
If the available free space in the job results directory is insufficient, incremental backup operations might fail.
Supported MongoDB and Percona Server Versions
MongoDB Versions
Operating system Processor architectures MongoDB 8.x MongoDB 7.x
Amazon Linux 2023 AMI x86_64 Yes Yes
Amazon Linux 2 x86_64 NA Yes
Debian 12 x86_64 Yes Yes
RHEL/Rocky/Alma/Oracle Linux 9.x x86_64 Yes Yes
RHEL/Rocky/Alma/Oracle Linux 8.x x86_64 Yes Yes
RHEL/Oracle Linux 7.x x86_64 NA Yes
SuSE Linux 15 x86_64 Yes Yes
SuSE Linux 12 x86_64 NA Yes
Ubuntu 24.04 x86_64 Yes NA
Ubuntu 22.04 x86_64 Yes Yes
Ubuntu 20.04 x86_64 Yes Yes
Windows Server 2022 x86_64 Yes Yes
Windows Server 2019 x86_64 NA Yes
  • The latest certified version of MongoDB 7.x is 7.0.14
  • The latest certified version of MongoDB 8.x is 8.0.4.
  • The mongodump and mongorestore database tools must be version 100.3.0 or later. The --config option used for YAML file–based input of credentials is available only in these versions.
Percona Server for MongoDB Versions
Percona Server 7.x
  • The most recent certified version of Percona Server for MongoDB 7.x is 7.0.14-8.
  • The mongodump and mongorestore database tools must support --config option for YAML–based credential input.
Access Node Requirements for Backup Copy Operations
The following hardware specifications apply to the access node that performs file system backup copy operations for MongoDB backups.
Components
Extra Large
Large
Medium
Small
Extra Small
CPU/RAM 1
16 CPU cores, 128 GB RAM (or 16 vCPUs/128 GB)
12 CPU cores, 64 GB RAM (or 12 vCPUs/64 GB)
8 CPU cores, 32 GB RAM (or 8 vCPUs/32 GB)
4 CPU cores, 24 GB RAM (or 4 vCPUs/24 GB)
2 CPU cores, 16 GB RAM (or 2 vCPUs/16 GB)
Front End Terabytes (FET) 2
90 TB to 120 TB
50 TB to 100 TB
25 TB to 50 TB
10 TB to 25 TB
5 TB to 10 TB
  1. Assumes latest generation CPU architecture.
  2. Front-End Terabytes (FET): The amount of client data that must be backed up.
