Deprecated
This engine is deprecated from the Commvault software in Commvault Platform Release 2023 (11.30).
See End-of-Life, Deprecated and Extended Support - Features for information about deprecated features.
Before you configure your storage array, verify that your environment the following requirements.
Licenses
Install the following licenses.
| Snapshot Type | License |
| Snapshot (NEC DynamicSnapVolume) | Snapshot (NEC DynamicSnapVolume) |
| Replication (NEC DynamicDataReplication) | Replication (NEC DynamicDataReplication) |
Version and Firmware
Use the following versions and firmware.
| Array | Version and Firmware |
| NEC | NEC M-Series with Storage Control Software version 087C |
Protocols
Use one of the following protocols.
| Array | Protocol |
| NEC | Fibre Channel |
Software
Install the following software.
| Arraye | Required Software |
| NEC | ControlCommand version 9.3.006 on the client computer |
Ports
You do not need to open any specific port.
