Before you configure your storage array, verify that your environment meets the following requirements.
Licenses
Install the following licenses.
| Snapshot Type | License |
| Snapshot | None |
Version and Firmware
Use the following version and firmware.
| Array | Version and Firmware |
| NetApp SolidFire |
Protocols
Use one of the following protocols.
For the Linux platform, the iSCSI support is only on Red Hat Enterprise Linux and CentOS 7.x.
| Array | Protocol |
| NetApp SolidFire |
Software
Install the following software.
| Array | Required Software |
| NetApp SolidFire | None |
Ports
You do not need to open any specific port.
