Before you configure your storage array, verify that your system meets the following requirements.
Licenses
Install the following licenses:
| Snapshot Type | License |
| Snapshot | None |
Version and Firmware
Ensure that you are using compatible versions and firmware:
| Array | Version and Firmware |
| Pure |
Protocols
Ensure that at least one of the following protocols is available:
| Array | Protocol |
| Pure | Fibre Channel iSCSI |
Software
Install the following software components:
| Array | Required Software |
| Pure | None |
Ports
For the REST API, the source clients, proxy computer, and the Remote Snapshot MediaAgent access the management IP of the array using port 443 (HTTPS).
