Before you configure your storage array, verify that your environment meets the following requirements.
Licenses
Install the following licenses.
| Snapshot Type | License |
| Silk Snap | None |
Version and Firmware
Use the following versions and firmware.
| Array | Version and Firmware |
| Silk |
Protocols
Use one of the following protocols.
Important
For iSCSI LUNs, configure the host in the same subnet of the storage array.
| Array | Protocol |
| Silk |
Software
Install the following software components:
| Array | Required Software |
| Silk | None |
Ports
You do not need to open any specific port.
