Before you configure your storage array, verify that your system meets the following requirements. Install the following licenses:
Licenses
| Snapshot Type | License |
| Snapshot | None |
Version and Software
Ensure that you are using compatible versions and firmware:
| Array | Version and Firmware |
| Western Digital IntelliFlash |
Protocols
Ensure that at least one of the following protocols is available:
| Array | Protocol |
Software
Install the following software components:
| Array | Required Software |
| Western Digital IntelliFlash | None |
