Before you configure your storage array, verify that your system meets the following requirements.
Licenses
Install the following licenses:
| Snapshot Type | License |
| Tintri VMstore Snap | None |
Version and Firmware
Ensure that you are using compatible versions and firmware:
| Array | Version and Firmware |
| Tintri VMstore |
Protocols
Ensure that at least one of the following protocols is available:
| Array | Protocol |
| Tintri VMstore | NFS 3.0 |
Software
Install the following software components:
| Array | Required Software |
| Tintri VMstore | None |
