This section describes how to measure Input Output Operations Per Second (IOPS) using Iometer, an industry standard tool. Measuring IOPS provides a standard and simplified way to help you commission disk storage for Search Engine nodes.
Minimum and Recommended IOPS for Search Engine Nodes
The minimum and recommended IOPS of Search Engine disk volumes depend on the type of Search Engine node being considered:
| Search Engine Node Type | Description | Minimum IOPS | Recommended IOPS |
| Search Engine node | The normal Search Engine node used to run content indexing jobs | 600 | 1200 |
| Search Only node |
 | 400 | 600 |
| Search Engine Node with ContentStore Email Viewer | A Search Engine node that is used to perform searches in the ContentStore Email Viewer of messages that were archived using OnePass for Exchange Mailbox (Classic). | 600 | 800 |
Consider the following before running the IOPS test with Iometer:
Ensure that each volume to be tested contains a minimum of 50 GB of free disk space.
If the drive containing the operating system is tested without at least 50 GB of free disk space, operating system corruption may occur.
If multiple Search Engine nodes use SAN attached LUNs belonging to the same disk array, test IOPS ratings concurrently on all nodes by running Iometer in parallel.
If the physical spindles behind the volume are shared between multiple volumes, it is important to make sure the load on the underlying physical disks remains the same as at the time of Iometer testing. Increase in load on the shared disks may result in degraded performance.
Run Iometer on Search Engine Nodes
Perform the following steps on each Search Engine node being tested with Iometer:
Right-click the Iometer profile link below and select the option to save the file to your computer: Note Save the Iometer profile to a location that is accessible from the Search Engine node client.
Stop all services on the Search Engine node. Refer to Stopping a Service for instructions.
In Windows Explorer, navigate to the tool directory, and then right-click Iometer > Run as Administrator. Note For installing the Iometer tool, see the Iometer website.
Click the open button  and select the CommVault IOmeter profile for Search Engine. and select the CommVault IOmeter profile for Search Engine.
Select the Search Engine index as the target disk for Worker 1 through Worker 24: -
In the Topology pane, click Worker 1.
In the Disk Targets tab, select the check box for the volume where the Search Engine index is located.
Repeat the previous two steps for Worker 2 through Worker 24.
Click the Results Display tab.
Click the run button  to start the test. to start the test.
When prompted, save the Iometer test results file to a location on the Search Engine node. As the test runs, results appear in the Results Display tab.
When the test is complete, start all services on the Search Engine node. Refer to Starting a Service for instructions.
+10. Open the Iometer test results file from the location specified at step 8.
Locate the IOPS number from the IOps column.
Compare this number to the minimum and recommended IOPS for Search Engine nodes.
