You can create a network topology instance in which members of either client group can connect to members of the other client group.
Verify that the client groups that you want to use in the network topology instance are already defined in the CommCell Console or the Command Center.
You must have Administrative Management permissions on the client groups that you plan to use in the network topology instance.
Both DMZ servers/infrastructure computers and servers/laptops should be able to open connections to each other on the tunnel port.
From the Command Center navigation pane, go to Manage > Network > Network Topologies.
The Network topologies page appears.
Click Add topology. The Add topology dialog box appears.
In the Name field, enter a name for this instance of a two-way direct connection.
For Client type, select Servers.
From the Topology type list, select Two-way.
Click Next.
From the Servers list, select the server group that will initiate connections with members of the infrastructure computers group.
Optional: Click the advanced toggle to edit the following options: -
Tunnel port. Set this to Default (8403), or enter another port number.
Keep-alive interval. The interval (in seconds) for sending keep-alive packets, to maintain the session if backup traffic has an extended pause. Set this to 180 (default), or enter another interval. To avoid idle session timeouts on cloud-based clients, set the interval to 200 seconds or less.
From the Backup infrastructure list, select the a server group that will initiate connections with members of the Servers group.
Optional: To edit the Tunnel port and Keep-alive interval options, as described in Step 9, above.
Click Next.
Optional: Edit the following advanced options: -
Move the Encrypt traffic toggle key to the right to encrypt network traffic (HTTPS).
Select Encrypted, Authenticated, Regular, or Raw from the tunnel protocol list.
Select the Parallel data transfer streams for long distance networks (default value is 1, and maximum value is 8).
Click Submit.
