Advanced Restore - IntelliSnap for UNIX File System
Performing the Initial UNIX File System IntelliSnap Restore
By default, the snapshot copy is set to 1 and is used for the restore operation. You can also use a different copy for performing the operation. For the copy that you want to use, set the copy precedence as 1 in the Copy Precedence tab of the Storage Policy Properties dialog box.
  1. From the CommCell Browser, expand to Client Computers > client > File System > backupset.
  2. In the right pane, right-click a subclient, and click Browse and Restore.
    The Browse and Restore dialog box appears.
  3. On the Advanced Options tab, from the Use MediaAgent drop-down list, select the MediaAgent that was used during storage policy creation.
    The MediaAgent must be the one you installed along with your agent.
  4. Click View Content.
  5. In the right pane of the CommCell Browser window, select the data that you want to restore, and click Recover All Selected.
  6. On the Restore Options - General tab:
    1. Clear the Overwrite Files check box.
    2. In the Destination Client list, select a client in the same CommCell as the client from which the data was backed up.
    3. Clear the Restore to same folder check box.
    4. In the Specify Destination Path box, enter the path on the destination client. Optionally, click Browse and in the Browsing for destination folder on client dialog box, select the destination folder and click OK.
      Important: Enter the path in Specify Destination Path box even if you are restoring to the same folder on the destination client.
      Restored data retains its original permissions. The ACLs are restored after the permissions are restored. Do not restore ACLs to any directory that has the "sticky bit" on.
  7. Click OK.
Restoring Data from a Backup Copy
You can perform a restore from the backup copy by setting the appropriate copy precedence number.
  2. Right-click the entity that contains the snapshots you want to restore, and point to All Tasks | Browse and Restore.
  3. Click View Content.
  5. From the Restore Options for All Selected Items window, click Advanced.
  6. Click the Copy Precedence tab and select the Restore from Copy Precedence check box.
  7. In the Copy Precedence box, type the copy precedence number for the backup copy.
  8. Click OK.
  9. Click OK to close the Restore Options window and start the restore job.
  • Different computer
Keep in mind that the destination computer must reside in the same CommCell as the client whose data was backed up.
Restoring to a Different Folder on the Same Client
  2. Right-click the <Subclient> in the right pane and then click Browse and Restore.
    For Example: If the selected data is /Documents/Memos/Sales, and you want to restore data only from the Sales folder, set the Preserve <n> level from end of source path option to 1.
    If the selected data is /Documents/Memos/Sales, and you want to restore the data from Memos and Sales folders, set the Remove <n> level from beginning of source path option to 2.
  8. Click OK.
Restoring Data to a Different Client
  1. From the CommCell Browser, expand to Client Computers > client > File System > backup set.
  3. In the Browse and Restore dialog box, click View Content.
  4. Select the data that you want to restore, and click Recover All Selected.
  5. On the Restore Options - General tab:
    1. In the Destination Client list, select a client in the same CommCell as the client from which the data was backed up.
    2. Clear the Restore to same folder check box.
    3. In the Specify Destination Path box, enter the path on the destination client. Optionally, click Browse and in the Browsing for destination folder on client dialog box, select the destination folder and click OK.
  6. When you are satisfied with your selections, click OK.
Once the restore is complete, the data is restored to the destination folder you specified in the Restore Options dialog box. If the folder you specified does not exist, a folder with the same name is created and the data is restored to that folder.
You can perform the following cross-platform restores :
  • Restores across all the supported versions of Unix.
  • Restores from Unix to all the supported versions of Windows.
  7. Click Browse to select the destination folder and click OK.
  8. Click OK.
Ignoring Errors When Restoring From or To an NFS Mount
During restore operations, errors are reported by the chown system call especially when the source or destination is an NFS mount and because changing file ownership as a root user is not allowed by the NFS server.
By default, such errors must be ignored manually to continue with the restore operation. However, you can choose to ignore such errors using ignoreChownErrors additional setting. To add or edit an additional setting, follow the steps in Add or Modify an Additional Setting.
Use these arguments:
  • In the Name field, type ignoreChownErrors. The Category and Type fields are populated automatically.
  • In the Value field, type:
    1 - to ignore EINVAL error
    2 - to ignore any error reported by chown
Using Multiple Streams to Restore Data
By default, restore operation uses a single stream. For faster restore operations, you can configure the restore operation to use multiple streams, and you can define alternate data paths. For more information, see GridStor® (Alternate Data Paths) - Overview.
Notes: You cannot use multiple streams for restore operations on clients with only File System Core package installed (Laptop Backup clients).
  • Verify that you have v11 Service Pack 6 or later installed on the source client computers and on the destination client computers.
  • Verify that the client computer whose data you want to restore was backed up using indexing. For more information, see Indexing.
  • For more information about general restore options, see Restore/Recover Options (General).
  • For more information about the Advanced Options, see Advanced Restore Options.
  1. From the CommCell Console, expand Client Computers > client > File System > backup set.
  2. In the right pane, right-click a subclient, and then click Browse and Restore.
    The Browse and Restore Options dialog box appears.
  4. Select the data that you want to restore, and then click Recover All Selected.
    The Restore Options dialog box appears.
  5. On the General tab, complete the following steps:
    1. In the Destination Client list, select the destination client computer.
    2. In the Number of Streams box, enter the recommended number of data streams that you want to use for the restore operation.
      Note: The actual number of streams used depends on the restore data set and the number of streams used to back up data.
  6. On the Job Initiation tab, choose how you want to initiate the restore jobs.
    For more information about job initiation options, see Restore Options (Job Initiation).
  7. Click OK.
The restore operation restores the selected data to the destination client computer.
Using Multiple Nodes to Restore Data to NFS-Mounted File System
By default, restore operation uses a single node when you perform restores to NFS-mounted file systems. For faster restore operations, you can configure the restore operation to use multiple nodes, and you can define alternate data paths. For more information, see GridStor® (Alternate Data Paths) - Overview.
If you want to perform restores to distributed file systems or to network file systems such as NFS-mounted file systems that are mounted across multiple computers, use multiple nodes.
Notes: You cannot use multiple nodes for restore operations on clients with only File System Core package installed (Laptop Backup clients).
  • Verify that you have v11 Service Pack 7 or later installed on the source client computers and on the destination client computers.
    1. From the Destination Client list, select the primary node for the restore operation.
    3. To use multiple nodes for the restore operation, select the Multiple Nodes check box.
    4. Click Advanced.
      The Advanced Restore Options dialog box appears.
    5. On the Data Access Nodes tab, in the Available Data Access Nodes list, select the secondary nodes that will participate in the restore operation, and then click Add.
      Notes:
      • All of the participating restore nodes must be at the same service pack level (v11 Service Pack 7 or later).
      • The destination volume must be shared across all the restore nodes and it must be accessible from all the nodes.
      • The destination volume must be mounted in the same directory on all the nodes.
      • All of the participating restore nodes must be time synced.
    7. In the Specify Destination Path, enter the NFS path.
      For example: /finite/nftest/test
  7. Click OK.
Renaming Files on Restore
If you do not want to overwrite the existing files during restores, you can append a suffix to the filenames and restore them as new files. (This suffix is appended to the filename before the extension.)
  7. Click Advanced.
  9. Enter the desired string that you want to append as a suffix to the filenames in Rename all restore files with suffix and click OK. For Example: Enter the string temp will rename file.txt to filetemp.txt.
  10. Click OK.
rename_files
Overwriting Data During Restores
  7. Click OK.
Clear the Overwrite Files check box when restoring to a computer that has different hardware and different software device drivers.
Restoring Only When Data Exists on the Destination
  7. Click OK.
Restoring Specific Data Backed Up During a Job
You can restore specific files and folders from the data backed up during the selected job. Follow the steps given below to restore specific files and folders from the selected backup job:'
  2. Right-click the subclient, and then click Backup History.
  3. In the Backup History Filter dialog box, select the Specify Time Range check box, and then enter the time range.
  4. Click OK.
  5. From the Backup Job History tab, right-click the job that contains the data to be restored, and then click Browse and Restore.
  6. In the Browse and Restore Options dialog box, click View Content.
  7. From the Browse window, select the data to restore, and then click Recover All Selected.
  8. In the Restore Options dialog box, select the desired restore options, and then click OK.
Restoring From a Failed or a Killed Job
You can restore from a failed or killed job. When Restoring from a Failed or a Killed Job, the data backed up to the point of failure will be restored.
Failed or killed backup jobs are immediately aged regardless of their defined retention rules, therefore, these jobs can only be restored if the media is not yet overwritten. You can restore aged data from tape media but cannot restore from disk libraries.
  3. In the Backup History Filter dialog box, click Failed or Killed in the Job Status area.
  4. Select the Specify Time Range check box, and then enter the time range in which the job was failed or killed.
  5. Click Advanced.
  6. In the Advanced Filter Options dialog box, select the Include Aged Data check box, and then click OK.
  7. Click OK.
  8. From the Backup Job History tab, right-click the job that contains the data to be restored, and then click Browse and Restore.
  9. In the Browse and Restore Options dialog box, click View Content.
  10. From the Browse window, select the data to restore, and then click Recover All Selected.
  11. In the Restore Options dialog box, select the desired restore options, and then click OK.
Resubmitting a Restore Job
  3. Click Data Recovery Operations.
  4. Select the Browse and Restore check box and clear all other check boxes.
  5. Click OK.
  6. Right-click the restore job that you want to resubmit from the Data Recovery Job History tab and click Resubmit Job.
  7. Click OK to start the restore.
resubmit_job
Filtering Data from Restores
  5. Click Advanced.
  7. Click Add for Source Item list and enter the path of the source data.
  8. If you want to remove any files or folders from the restore operation, click Add for Filter Item list and enter the path of the data. Wildcard entries must be expressed as complete paths.
    Make sure that the filter items specified are available in the source items selected.
  9. Click OK.
filter_paths
The following wildcards can be used in filters to include or exclude data when restoring data.
Wildcards
Examples
Any number of characters.
*.doc will filter all files with the extension .doc (e.g., status.doc, mission.doc) on all partitions on the client computer.
/Test/*.doc will filter all .doc files only in the /Test directory
a*.so will filter all files with the extension .so (e.g., alsvc.so, advdcc.so) on the client computer which have the name beginning with "a".
/Finance/Test/* will filter all the files and directories in the "Test" directory under the "Finance" directory on the / partition. Any sub-directories under the Test directory will not get backed up.
Any one character.
This wildcard can be used in the following scenario:
All files (or directories) for which any one character in the file name or the directory name is variable.
/access? will filter any directory or file on the machine for which the name begins with- "access" followed by any one character such as access1 or access5. However, access12 or access15 will not get backed up because the last two characters in the name are variable.
/Class/report? will filter any directory or file under /Class directory for which the character in the place of ? is variable. For example: /Class/report1 and /Class/report2 will get backed up. However, /Class/report15 will not get backed up.
Set or range of characters.
/[a-m]*.doc will filter any file with .doc extension on the / partition for which the name begins with the letters "a" through "m”.
/[AEIOU]*.doc will filter any file name that ends with .doc and begins with the letters A, E, I, O, or U.
/Finance/report[1-47-9] will filter files report1, report2, report4, report7, report8, report9 under Finance directory.
/Department-[A-CS] will filter files Department-A, Department-B, Department-C and Department-S.
The negation of a set or range of characters. You can use the wildcard in the following scenario:
Filter all files in a directory except the files for which the name starts with any character from the specified set or range of characters.
/root/[!AEIOU]*.doc would filter all .doc files in the /root directory that start with a letter other than A, E, I, O, or U.
Any number of characters across any number of path levels.
/**/move.cpp - the file named move.cpp located at any directory level. (e.g., /root/newapp/move.cpp/opt/kde3/src/move.cpp)
/etc/** - will filter all directories and files under /etc. All the sub-directories under these directories will also be included.
If you want all the files with the file extension ".doc" to be filtered from any level, then specify the content as *.doc. If any subclient content does not start with /, then /**/ will be prefixed to the content to match at any level. E.g., *.doc will be /**/*.doc
If user wants to treat *, ?, [ ] as literals in the subclient content and not as wildcards, then the user can escape the wildcard by adding ‘\’ before the wildcard. E.g., /Report\[2011-2012\]/*.doc filters all the .doc files under /Report[2011-2012]
You can restore individual files and folders to different locations using a map file containing a list of files to be restored, with their corresponding restore paths. If you are restoring hard-linked file backed up with HLINK additional setting set to Y, make sure that all the associated hard links are also included in the map file. This will allow you to preserve the hard links.
Creating a Map File
The map file is a text file in the CSV (Command Separated Value) format. Follow the steps given below to create a map file:
    • If the specified destination folder is not available, the necessary destination folder will be created during the restore.
The specified paths for both the source and destination should be absolute paths within the same client computer.
You can provide following information in a map file:
Information
Example
File to File Mapping
"/dir1/file1.txt","/dir2/file1.txt"
Folder to folder mappings
"/dir2/info/","/dir4/info/"
Drive to drive mappings
"/"(root),"/mnt","/usr"
Rename files/folder during restore
"/dir4/file2.txt","/dir5/file3.txt"
Filter certain files
"/dir5",""
Adding Files and Folders with Unicode Characters to a Map File
    ./CVconvertUnicode <source file> <destination file>
    where:
Restoring Using a Map File
  5. Click Advanced.
  6. Select the Map tab.
  9. Click OK.
map_file_1
Combining Browse and Restore with the Map File Restore
Use the following procedure to restore a set of files to a specified location with some files within that set to different destinations.
  5. Click Advanced.
  9. Click OK.
map_file_2
Restoring Deleted Files
You can restore deleted files using the following steps:
  5. Click Advanced.
  8. Select the time range to restore the files deleted in that period of time.
  9. Click OK.
  5. Click Advanced.
  6. Click the Pre/Post tab.
  7. If you want perform a process before the restore job, enter the path for the batch file in the Pre Recovery Command box or click Browse to select the batch file.
  8. If you want perform a process after the restore job, enter the path for the batch file in the Post Recovery Command box or click Browse to select the batch file.
  9. Click OK.
Setting Up a Pre-process and Post-process to Run after Each Attempt
  8. Click OK.
post_rest_process
Restoring Sparse Files
Restoring Raw Device Files and Special Files
By default, device files and special files are not created during restores if they do not exist.
The following files are not created by default during restores:
  • Device files (character and block devices)
  • Special files (non-regular)
  • Pipe files
  • Socket files
  • Door files (on Solaris)
The device files can be restored either in place or out of place. You can restore only entire device files. Use character device files instead of block device files for achieving better restore performance.
To create device files and special files if they do not exist:
Use this additional setting at your own risk because failure to create device nodes might result in inconsistent restores.
  1. From the CommCell Console, expand Client Computers > client > File System.
  2. Right-click the appropriate backup set, point to All Tasks and then click Browse and Restore.
  4. Select the raw device data from the right pane.
  5. Click Recover All Selected.
    The Restore Options for All Selected Items dialog box appears.
  6. Select the Data in device node check box.
  7. Select the Overwrite files check box, and then click Unconditional Overwrite.
  8. In the Destination Client list, select the destination client.
  9. Clear the Restore to same folder check box.
You can track the progress of the job from the Job Controller.
Restoring Raw Device Files as Regular Files
You can restore the actual data in the device node file of the raw partition as a regular file system file.
  2. Right-click the <Backup Set>, point to All Tasks and then click Browse and Restore.
  4. Select the raw device data that you want to restore and click Recover All Selected.
  5. Click Data in device node.
  6. Select Overwrite files and then click Unconditional Overwrite.
  7. Clear the Restore to same folder check box.
  8. Select the name of the client computer from the Destination Client list.
  9. Click Browse to navigate to the destination path.
  10. Click Advanced.
  11. Select Restore device files as regular files check box.
  12. Click OK.
  13. Click OK to start the restore.
Restoring Macintosh Files
You can restore Apple Double formatted Macintosh files that contain resource fork data.
Enabling a Global Option to Restore Resource Fork Data
  1. From the CommCell Console, click the Control Panel button in the toolbar.
  2. Double-click the Browse/Search/Recovery icon.
  3. Select Recover Apple Resource Fork Data check box.
  4. Click OK.
apple_fork_data
Restoring Resource Fork Data for a Specific Job
Use the following steps to recover Apple resource fork data of selective Macintosh files.
  4. Select the MAC File System data that you want to restore and click Recover All Selected.
  5. Click Advanced.
  6. Select Recover Apple Resource Fork Data check box.
  7. Click OK.
restore_mac_data
Excluding ACLs from Restores
The ACLs and the data are restored by default when you restore the data . Use the following procedure to exclude the ACLs from the restore.
  2. Right-click the subclient in the right pane and then click Browse and Restore.
  5. Click to clear the Restore ACLs check box.
Listing Media
List media option is useful to predict media required for the following operations:
  • To restore data associated with a specific backup set or subclient.
  • To restore the index required to browse data associated with a specific backup set or subclient.
  • To restore a specific file (or specific files and folders).
  • To restore data associated with a specific job.
The List Media feature can also be used in a number of other capacities. Refer to the List Media documentation for a complete overview of this feature.
The list media operation can be performed for backup sets and subclients. The following sections describe each of these methods.
Listing Media for a Subclient
  2. Right-click the subclient for which you wish to list media and then click Browse and Restore.
  3. From the Restore Options dialog box, if required, select the following options:
    • Click Latest Backup to list media associated with the most recent data protection cycle.
    • Click Time Range to list media associated with data protection operations up for the specified date and time range. Select the Start Time and End Time check boxes to specify the start and end dates along with time.
    • Click Relative Time to list media associated with data protect operations for the specified relative time in terms of Days, Weeks, Months or Years.
  4. Click List Media.
  5. From the List Media dialog box, click List Media for restore within specified time range.
The appropriate media is listed in the Media dialog box.
Listing Media for a Backup Set
  2. Right-click the backup set for which you wish to list media, point to All Tasks and then click Browse and Restore.
Listing Media and Size for a Backup Set
  2. Right-click the <Backup Set> in the right pane and then click Browse and Restore.
  5. Click OK.
Scheduling a Restore
  6. Click Configure.
    • Click Weekly.
Managing Restore Jobs
Once you initiate the restore operation, a restore job is generated in the Job Controller. Jobs can be managed in a number of ways. See Job Management for a comprehensive information on managing jobs. The following sections provide information on the different job management options available:
Restarting Jobs
  4. Click OK.
  2. Click OK.
Controlling Jobs
Suspend
Resume
Kill
Terminates a job.
Suspending a Job
Resuming a Job
Killing a Job
Additional Options
Option
Related Topic
Startup Options
  2. Right-click the <Backup Set> and then click All Tasks|Browse and Restore.
  5. In the Restore Options for All Selected Items dialog box, click Advanced.
  6. In the Advanced Restore Options dialog box, click Startup.
  7. In the Startup tab, select Change Priority.
  8. Enter a priority number. 0 is the highest priority and 999 is the lowest priority.
  9. Select the Start up in suspended State check box to start the job in a suspended state.
  10. Click OK.
Copy Precedence
By default, the system retrieves data from the storage policy copy with the lowest copy precedence. If the data was pruned from the primary copy, the system automatically retrieves data from the other copies of the storage policy in the lowest copy precedence to highest copy precedence order. Once the data is found, it is retrieved, and no further copies are checked.
You can retrieve data from a specific storage policy copy (Synchronous Copy or Selective Copy). If data does not exist in the specified copy, the data retrieve operation fails even if the data exists in another copy of the same storage policy. Follow the steps given below to retrieve the data from a specific storage policy copy:
  6. In the Advanced Restore Options dialog box, click Copy Precedence.
  7. On the Copy Precedence tab, select the Restore from copy precedence check box.
  8. Enter the copy precedence number.
  9. Click OK.
Refer to Recovering Data From Copies.
Data Path Options
  6. In the Advanced Restore Options dialog box, click Data Path.
  7. On the Data Path tab, select the MediaAgent and Library.
  8. Select the Drive Pool and Drive for tape library.
  9. Select the name of the Proxy server if you wish to restore using a proxy server.
    You can select the Proxy server only when you are restoring from a snapshot. This option is not available for a regular restore.
  10. Click OK.
Refer to Change Data Path.
Encryption
  6. In the Advanced Restore Options dialog box, click Encryption.
  7. Enter the Pass Phrase.
  8. Click OK.
Refer to Data Encryption.
Alerts
  5. In the Restore Options for All Selected Items dialog box, click Advanced.In the Advanced Restore Options dialog box, click Alerts.
  6. Click Add Alert.
  7. From the Add Alert Wizard dialog box, select the required threshold and notification criteria and click Next.
  8. Select the required notification types and click Next.
  9. Select the recipients and click Next.
  10. Click Finish.
  11. Click OK.
CommCell Readiness Report
  2. Click Readiness.
  7. Click OK.
  10. Click Run.
Restore Job Summary Report
  2. Click Summary.
  4. On the General tab, select Data Recovery Jobs.
  5. Select the Computers tab.
  6. Select the appropriate client and the appropriate agent.
  7. Click Run.
Refer to Restore Job Summary Report.
