Configuring the DataCore SANsymphony-V Storage Array Using Array Management
For IntelliSnap backups from Commvault software, add the DataCore SANsymphony-V storage array and its configuration information to the CommServe database.
  1. On the ribbon in the CommCell Console, click the Storage tab, and then click Array Management.
    The Array Management dialog box appears.
  2. Click Add.
    The Array Properties dialog box appears.
  3. On the General tab, specify the following information:
    1. From the Snap Vendor list, select DataCore.
    2. In the Name box, enter the name of the DataCore SANsymphony-V server.
    3. In the Control Host box, enter the name of the DataCore SANsymphony-V server.
    4. In the Credentials area, click Change.
      The Enter the User Name and Password dialog box appears.
    5. Type the credentials of a user who has the virtual disk privilege and the snapshot privilege. The user name must match the administrator user account name in the Windows operating system of the DataCore server computer.
  4. To configure additional MediaAgents to perform operations on the storage array, click the Array Access Nodes tab, and then select configuration options.
    For more information, see Configuring Array Controllers.
  5. Click OK.
