Configuring Pre- and Post-Processing Scripts Using VMware Tools
You can use VMware tools to perform specific operations before or after a backup. For example, if a virtual machine hosts an Oracle database and you want to enable a Hot backup of the database before performing a backup, you can run a script using VMware tools.
By default, custom quiescing scripts for Linux are stored in /etc/vmware-tools/backupScripts.d/. If that directory does not exist or is empty, the system runs any scripts that are in the legacy directory of C:Windowspre-freeze-script.bat on Windows and /usr/sbin/pre-freeze-script on Linux. For more information, see Running custom quiescing scripts inside Windows & Linux virtual machines (1006671).
For ESX version4.x, store the VMware tools scripts in C:\Program Files\VMware\VMware Tools\backupScripts.d.
The following scripts are available to perform pre- or post-processing using VMware tools:
Operation
Scripts
Scripts can be used to take a snapshot of a VM with the DB2 application. These scripts enable VMware to suspend I/O updates to the DB2 database until the VMware Linux guest snapshot is completed.
  1. On a Linux virtual machine, copy the pre-freeze-script and post-thaw-script to the /usr/sbin directory.
  2. Copy the write_suspend and write_resume scripts to a location where the DB2 database can execute them (preferably to a directory under DB2 home).
pre-freeze-script
post-thaw-script
write_resume.sh
write_suspend.sh
Scripts can be used to take a snapshot of a VM with the MAXDB application. These scripts enable VMware to suspend I/O updates to the MAXDB database until the VMware Linux guest snapshot is completed.
  2. Copy suspend_logwriter and resume_logwriter scripts to a location where MAXDB database can execute them (preferably to a directory under MAXDB home).
pre-freeze-script
post-thaw-script
resume_logwriter.sh
suspend_logwriter.sh
Scripts can be used to take a snapshot of a VM with the Oracle application. These scripts enable VMware to suspend I/O updates to the Oracle database until the VMware Linux guest snapshot is completed.
  2. Copy the pre-freeze-script.sql and post-thaw-script.sql scripts to a location where the Oracle database can execute them (preferably to a directory under Oracle home).
    These scripts change the entire database to backup mode.
    If the virtual machine has the Oracle iDataAgent installed on it, you can also use the consistent-archivelog-backup.rman script as a sample to run archivelog backup. This script gets a consistent snapshot, all the latest archived logs, and the current control file.
pre-freeze-script
post-thaw-script
Scripts can be used to take a snapshot of a VM with the Sybase application. These scripts enable VMware to suspend I/O updates to the Sybase database until the VMware Linux guest snapshot is completed.
  2. Copy pre-freeze-script.sql and post-thaw-script.sql scripts to a location where the Sybase database can execute them (preferably to a directory under Sybase home).
    These scripts execute Sybase quiesce commands that stop updates to the databases.
pre-freeze-script
post-thaw-script
Scripts can be used to take a snapshot of a VM with the MySQL application. These scripts enable VMware to suspend I/O updates to the MySQL database until the VMware Linux guest snapshot is completed.
  2. Copy the quiesce.py and unquiesce.py scripts to a location where the MySQL database can execute them (preferably to the /usr/sbin directory).
    A Python script is used to quiesce and unquiesce the databases. Python and MySQL-Python modules must be installed on the client computer.
pre-freeze-script
post-thaw-script
unquiesce.py
quiesce.py
Scripts can be used to take a snapshot of a VM with the MongoDB application. These scripts enable VMware to suspend I/O updates to the MongoDB database until the VMware Linux guest snapshot is completed.
  2. Copy the quiesce.sh and unquiesce.sh scripts to a location where the MongoDB database can execute them (preferably to the /opt/cv_mongodb_snap directory).
    A shell script is used to quiesce and unquiesce the server.
    The cv_mongodb_properties file under /opt/cv_mongodb_snap must have the parameters mentioned if applicable. Logging information will be in the file /opt/cv_mongodb_snap/logfile.
To disable automatic fall back of a non-quiesced snapshot, set the requireSnapshotGuestFileSystem additional setting to true. For instructions about adding an additional setting from the CommCell Console, see Adding an Additional Setting from the CommCell Console.
pre-freeze-script
post-thaw-script
unquiesce.sh
quiesce.sh
Scripts can be used to take a snapshot of a VM with the Informix application. These scripts enable VMware to suspend I/O updates to the Informix database until the VMware Linux guest snapshot is completed.
  2. Make sure to modify the Informix specific environmental variables defined in both the scripts to match your server.
pre-freeze-script
post-thaw-script
