Enabling Block-Level Backup Operations for SQL Databases
If you want to perform block-level backup operations on a SQL database, then you must select the Optimize for table level restore check box at the subclient level.
  1. From the CommCell Console, click Client Computers > client > SQL Server > instance.
  2. Right-click a subclient for which you want to enable block-level backup operations, and then click Properties.
  3. On the Advanced Options tab, select the Optimize for table level restore check box.
    A message appears that tells you that the next backup will be converted to a full backup.
  4. Click OK to close the message.
  5. Click OK.
Performing a Block-Level Backup on SQL Databases
