Enabling CommCell Communication Using IPv6 After Installation
You can enable IPv6 support on a computer after installing Commvault software on it.
You must perform these steps on each computer in a CommCell group.
  2. Right-click the client > Properties > Advanced.
  3. Click the Additional Settings tab, and then click Add.
  4. In the Name field, type nPreferredIPFamily.
  5. In the Value field, enter one of the following values:
    • 0 for both IPv4 and IPv6 support
    • 1 for IPv4 support only
    • 2 for only IPv6 support only
  7. Restart the Commvault services.
