Monitoring Job Progress Using the Commvault Plug-In
You can monitor the progress of the backup and the restore jobs while they are running. You can see information like the job phase, current status and delay reason, if any.
You will be able to see only those jobs that are running on the client on which the Commvault Plug-in is configured.
  1. Open the SQL Management Studio as administrator.
  2. In the Object Explorer, right-click a database, and then click Data Protection Tasks > Plugin Job Monitor.
    The Plugin Job Monitor dialog box is displayed.
You can view the progress of the backup and the restore jobs running on the client. You can right click to suspend, resume or kill the jobs.
