Remote Installation Using the CommCell Console
You can configure a direct connection from the CommServe computer to the client during a remote installation of the Commvault software using the CommCell Console.
  1. On the Network Route Configuration page of the installation wizard, select the There is Firewall between Client machine and CommServe check box, and then click the CommServe can open connection towards client machines option.
  2. In the Local HTTP/HTTPS tunnel port number box, specify a local port number on which the client will receive communication from the CommServe computer.
  3. Click Next to continue with the client installation.
