DB2 MultiNode Cross Database/Cross Instance/Cross Machine Restore
Requirements:
  1. The source and target DB2 DPF databases must have the same number of nodes.
  2. Commvault must be installed on all target DB2 DPF machines and there must be a configured pseudo client in the CommServe.
  3. In the case of a partial restore, the DB2 DPF NODE0 tables space "SYSCATSPACE" must be part of a partial redirect restore.
Use the following steps to perform a cross-database / cross instance / cross machine restore.
For cross database restores, run all DB2 commands on the target machines for the DB2 instances/DB2 database.
For DB2 DPF
  1. At the Command Prompt, type the restore command.
    For non-automatic storage database:
    export DB2NODE=$[n]
    db2 terminate
    db2 restore db $[Source DB2 Database Name] \
    load '$[software install path]/Base/libDb2Sbt.so' \
    open $[n] sessions \
    'options "\
     CvDpfClientName=$[Target MultiNode Pseudo Client Name],\
     CvDpfControlHostName=$[Target Client Name],\
     CvSrcClientName=$[Source MultiNode Pseudo Client Name],\
     CvSrcDB2InstanceName=$[Source DB2 Database Name],\
     CvSrcDbName=$[Source DB2 Database Name], \
     CvInstanceName=$[Instance001]"' \
     taken at $[Source DB2 Database NODE<n> backup image date] \
     to '$[Target DB2 Database Path]' \
    into $[Target DB2 Database Name] \
    without prompting
    For automatic storage database:
    export DB2NODE=$[n]
    db2 terminate
     'options "\
     CvSrcDB2InstanceName=$[Source DB2 Database Name], \
     CvSrcDbName=$[Source DB2 Database Name],\
     ON '$[Target DB2 Database Path]' \
     DBPATH ON '$[Target DB2 Database Path]' \
    without prompting
    Where:
    n = DB2 Node Number
    CvDpfClientName = Target MultiNode pseudo client name in Commvault CommServe
    CvDpfControlHostName = Target DB2 client name
    CvSrcClientName = Source MultiNode Pseudo client name in Commvault CommServe
    CvSrcDB2InstanceName = Source DB2 instance name
    CvSrcDbName = Source DB2 database name
    CVInstanceName= Commvault instance name
    taken at = Source DB2 Database NODE<n> backup image date
    ON = Target DB2 Database storage path
    DBPATH ON = Target DB2 database directories path
    Into = Target DB2 database name
  2. Re-update the db2 database configuration parameters LOGARCHOPT1/VENDOROPT since they are overwritten by source database after restore. Set the CvSrcDbName option for the LOGARCHOPT1 parameter to the source database name.
  3. Roll forward the DB2 database.
    export DB2NODE=0
     db2 terminate
    db2 update db cfg for $[database name] DBPARTITIONNUM (n) using LOGARCHOPT1 "'\
     CvDpfClientName=$[Target_ Db2MultiNode_PesudeoClientName],\
     CvDpfControlHostName=$[Target_DB2_Client_Machine_Name],\
     CvSrcClientName=$[Source_ Db2MultiNode_PesudeoClientName],\
     CvSrcDB2InstanceName=$[Source_DB2DPF_Instance_Name],\
     CvSrcDbName=$[Source_DB2_Database_Name],\
    db2 update db cfg for $[database name] DBPARTITIONNUM (n) using VENDOROPT "'\
     CvSrcClientName=$[Source_Db2MultiNode_PesudeoClientName],\
     db2 rollforward db $[new_db] to end of logs and stop
For DB2 pureScale
    'options "\
     CvSrcDB2InstanceName=$[Source DB2 Instance Name],\
     taken at $[Source DB2 Database backup image date] \
    without prompting
    Where:
    n = DB2 Node Number
    CvDpfClientName = Target MultiNode Pseudo Client Name in Commvault CommServe
    CvDpfControlHostName = Target DB2 Client Name
    CvSrcClientName = Source MultiNode Pseudo Client Name in Commvault CommServe
    CvSrcDbName = Source DB2 Database Name
    CVInstanceName = Commvault instance name
    ON = Target DB2 Database Storage Path
    DBPATH ON = Target DB2 Database Directories Path
    Into = Target DB2 Database Name
    db2 update db cfg for $[database name] using LOGARCHOPT1 "'\
    db2 update db cfg for $[database name] using VENDOROPT "'\
