Verify that your environment meets the system requirements for block-level backup for UNIX.
Operating System
Important
Use the most recent version of the operating system that is listed. The Commvault software fully supports the most recent version of an operating system, until the vendor ends support. More recent versions of the Commvault software might not install on operating systems that are not supported by the vendor anymore. For information about the support lifecycle of an operating system, contact the vendor.
AIX
Operating system |
Processor architecture |
AIX 7.2 TL 01 SP01 ("7200-01-01-1642") 64-bit, or higher |
PowerPC (including IBM System p) |
AIX 7.1 TL 01 SP10 ("7100-01-10-1415") 64-bit, or higher |
AIX 6.1 TL 07 SP10 ("6100-07-10-1415) 64-bit, or higher |
4K disks are not supported for block level backups.
Linux
Operating system |
AlmaLinux 9.3 with kernel 5.14.0-362.8.1.el9_3.x86_64 |
x64 |
CentOS 8.4 with kernel 4.18.0-305 |
CentOS 8.3 with kernel 4.18.0-240 |
CentOS 8.2 with kernel 4.18.0-193 |
x64 |
CentOS 8.1 with kernel 4.18.0-147.0.3 |
x64 |
CentOS 8.0 with kernel 4.18.0-80 |
x64 |
CentOS 7.9 with kernel 3.10.0-1160 |
x64 |
CentOS 7.8 with kernel 3.10.0-1127 |
x64 |
CentOS 7.7 with kernel 3.10.0-1062 |
x64 |
CentOS 7.6 with kernel 3.10.0-957 |
x64 |
CentOS 7.5 with kernel 3.10.0-862 |
x64 |
CentOS 7.3 with kernel 3.10.0-514 |
x64 |
Debian 12.x with kernel 6.1.0-26-amd64 |
Debian 11.x with kernel 5.10.0-24 |
Debian 10.x with kernel 4.19.0-25 |
Debian 10.x with kernel 4.19.0-23 |
Debian 10.x with kernel 4.19.0-9 |
Debian 10.x with kernel 4.19.0-8 |
Debian 10.x with kernel 4.19.0-6 |
Debian 9.x with kernel 4.9.0-15 |
Debian 9.x with kernel 4.9.0-14 |
Debian 9.x with kernel 4.9.0-13 |
Debian 9.x with kernel 4.9.0-6 |
Debian 8.x with kernel 3.16.0-5 |
Debian 8.x with kernel 3.16.0-4 |
Debian 7 with kernel 3.2.0-4-amd64 |
Oracle Linux 9.x with kernel 5.15.0-3.60.5.1 |
x64 |
Oracle Linux 9.x with kernel 5.15.0.x |
x64 |
Oracle Linux 8.7 with kernel 4.18.0-425.10.1 |
x64 |
Oracle Linux 8.5 with kernel 5.4.17-2136.302.6.1.el8uek.x86_64 |
x64 |
Oracle Linux 8.x with kernel 4.18.0.x |
x64 |
Oracle Linux 7.x with kernel 3.8.13.x |
x64 |
Oracle Linux 7.9 with kernel 5.4.17-2102.201.3.el7uek.x86_64 |
x64 |
Oracle Linux 7.6 with kernel 4.14.35-1818.4.5.el7uek.x86_64 |
x64 |
Oracle Linux 7.5 with kernel 4.1.12-124.14.2.el7uek.x86_64 |
x64 |
Oracle Linux 7.4 with kernel 4.1.12-112.14.1.el7uek.x86_64 |
x64 |
Oracle Linux 7.3 with kernel 4.1.12-61.1.18.el7uek.x86_64 |
x64 |
Oracle Linux 7.2 with kernel 3.8.13-98.7.1.el7uek.x86_64 |
x64 |
Oracle Linux 7.1 with kernel 3.8.13-55.1.6.el7uek.x86_64 |
x64 |
Oracle Linux 6.10 with kernel 4.1.12 |
x64 |
Oracle Linux 6.9 with kernel 4.1.12-61.1.28.el6uek.x86_64 |
Oracle Linux 6.8 with kernel 4.1.12-37.3.1.el6uek.x86_64 |
Oracle Linux 6.7 with kernel 3.8.13-68.3.4.el6uek.x86_64 |
Oracle Linux 6.6 with kernel 3.8.13-68.1.3.el6uek.x86_64 |
Oracle Linux 6.4 with kernel 2.6.39-400 |
RedHat Enterprise Linux 9.3 with kernel 5.14.0-362 |
RedHat Enterprise Linux 9.2 with kernel 5.14.0-284 |
RedHat Enterprise Linux 9.0 with kernel 5.14.0-70 |
RedHat Enterprise Linux 8.8 with kernel 4.18.0-477 |
RedHat Enterprise Linux 8.7 with kernel 4.18.0-425 |
RedHat Enterprise Linux 8.6 with kernel 4.18.0-372 |
RedHat Enterprise Linux 8.5 kernel 4.18.0-348.2.1 |
RedHat Enterprise Linux 8.4 with kernel 4.18.0-305 |
RedHat Enterprise Linux 8.3 with kernel 4.18.0-240 |
Red Hat Enterprise Linux 8.2 Advanced Platform with kernel 4.18.0-193 |
x64 |
Red Hat Enterprise Linux 8.1 Advanced Platform with kernel 4.18.0-147.0.3 |
x64 |
Red Hat Enterprise Linux 8.0 Advanced Platform with kernel 4.18.0-80 |
x64 |
Red Hat Enterprise Linux 7.9 Advanced Platform with kernel 3.10.0-1160 |
x64 |
Red Hat Enterprise Linux 7.8 Advanced Platform with kernel 3.10.0-1127 |
x64 |
Red Hat Enterprise Linux 7.7 Advanced Platform with kernel 3.10.0-1062 |
x64 |
Red Hat Enterprise Linux 7.6 Advanced Platform with kernel 3.10.0-957 |
x64 |
Red Hat Enterprise Linux 7.5 Advanced Platform with kernel 3.10.0-862 |
x64 |
Red Hat Enterprise Linux 7.4 Advanced Platform with kernel 3.10.0-693 |
x64 |
Red Hat Enterprise Linux 7.3 Advanced Platform with kernel 3.10.0-514.10.2.el7 |
x64 |
Red Hat Enterprise Linux 7.1 Advanced Platform with kernel 3.10.0-229 |
x64 |
SUSE Linux Enterprise Server 15 SP4 with kernel 5.14.21-default |
SUSE Linux Enterprise Server 15 SP2 with kernel 5.3.18-24.12-default |
SUSE Linux Enterprise Server 15 SP1 with kernel 4.12.14-197.51-default |
SuSE Linux 15 Enterprise Server with kernel 4.12.14-25.22 |
SuSE Linux 12 SP5 Enterprise Server with kernel 4.12.14-120 and later |
x64 |
SuSE Linux 12 SP4 Enterprise Server with kernel 4.12.14-95.60 and later |
x64 |
SuSE Linux 12 SP3 Enterprise Server with kernel 4.4.82-6.9 |
SuSE Linux 12 SP2 Enterprise Server with kernel 4.4.121-92.92 |
SuSE Linux 12 SP2 Enterprise Server with kernel 4.4.38-93 |
SuSE Linux 12 Enterprise Server with kernel 3.12.49-11-default (Update 1) |
SuSE Linux 11 SP4 Enterprise Server with kernel 3.0.101-63 |
SuSE Linux 11 SP2 Enterprise Server with kernel 3.0.13-0.27-default |
SuSE Linux 11 Enterprise Server with kernel 2.6.32.12-0.7-default |
SuSE Linux 10 Enterprise Server with kernel 2.6.16.60-0.54.5 (Update 3) |
SuSE Linux 10 Enterprise Server with kernel 2.6.16.60-0.21 (Update 2) |
SuSE Linux 10 Enterprise Server with kernel 2.6.16.46-0.12 (Update 1) |
Rocky Linux 8.6 with kernel 4.18.0-477 |
Rocky Linux 8.7 with kernel 4.18.0-477 |
Rocky Linux 8.8 with kernel 4.18.0-477 |
Solaris
Operating system |
Solaris 11.3 |
Solaris 11.2 |
Solaris 11.0 |
Solaris 10 Update 7 or higher |
File Systems
All the blocks in a raw or block device are backed up during block-level backups. For supported file systems, only the blocks that contain data are backed up.
Block-level backups are not supported for NFS volumes.
The following table lists the file systems supported for each supported operating system:
File system |
Operating system |
Support for Change Block Tracking Using CVBF (Block Filter Driver) |
Data blocks backup support |
Extended 3 File System (ext3) |
Linux |
Yes |
Yes |
Extended 4 File System (ext4) |
Linux |
Yes |
Yes |
'X' File System (XFS) |
Linux |
Yes |
Yes |
Virtual FAT (vfat) |
Linux |
Yes |
No |
Journal File System (JFS2) |
AIX |
Yes |
Yes |
UNIX File System (UFS)* |
Solaris |
Yes |
No |
Veritas File System (VxFS) |
Solaris, AIX |
Yes |
Yes |
Zettabyte File System (ZFS)* |
Solaris |
Yes |
No |
Live browse and file-level restores are not supported for raw devices.
ZFS must span the entire disk. Disk slices are not supported.
For the Solaris File System Agent, the CVBF cache must be a UFS file system. For example, /opt/commvault/CVBF/cache.
Volume Managers
AIX LVM
Linux LVM
VxVM
Space Requirements in the LVM Group
For Linux LVM snaps, the LVM volume group must have enough space for snapshot creation. The default COW cache size is set to 4096 MB or 5% of the volume size, whichever is greater. To increase the COW cache size, configure the nSnapCowSizeMB additional setting. For instructions about adding the additional setting, see Adding an Additional Setting from the CommCell Console.
For CVBF snaps, the COW files are created in the software_install_path/CVBF/cache directory by default. Over time, the COW files can grow significantly and fill up the volume. To move the COW files to another volume, configure the sCVBFSNAPPART additional setting. For instructions about adding the additional setting, see Adding an Additional Setting from the CommCell Console.
Device
- VirtIO
Clustering
If clustering is supported by the operating system, you can install the software on a cluster. For information about supported cluster types, see Support for Cluster Configuration.
Hard Drive
Component |
Space required |
Software |
1 GB |
Job results folder |
To calculate the disk space requirements for the job results directory, see Job Results Directory Disk Space Calculation. Some agents and components require additional disk space, see Agents and Components Requiring Additional Disk Space. |
Log folder |
500 MB |
Location of the Default Temporary Directory for the Commvault Software
For Unix clients, the default temporary directory location /opt/commvault/Base/Temp for the Commvault software must be under the same mount point as the Job Results folder. You can set the default temporary directory for the software by configuring the dGALAXYTEMPDIR registry key on the client computer. For instructions about adding an additional setting from the CommCell Console, see Adding an Additional Setting from the CommCell Console.
DISCLAIMER
