Enabling or Disabling a Mount Path for Write Operations
You can disable (or enable) a cloud mount path for write operations to prevent new data from being written to them. If a mount path is disabled, the mount path can be used for restore purposes only.
  1. From the CommCell Browser, navigate to Storage Resources | Libraries | <Cloud Storage Library>.
  2. Right-click the <Cloud Storage Mount Path>, and then click Properties.
  3. From the Allocation Policy tab, select one of the following options:
    • To disable the mount path for write operations, select the Disable mount path for write option.
    • To enable the mount path for write operations, select either the Maximum Allowed Writers or the Allocate No. of Writers options. (This will unselect the Disable mount path for write option.)
  4. Click OK.
