Installations Using the Installation Package
Use one of the following methods to deploy the Commvault software on your environment by using the installation package.
Install Locally on a Computer
You can install the Commvault software interactively on a computer. This type of installation is known as local installation, because you directly install the software on a computer.
Based on your computer's operating system, see installing locally on Windows, UNIX or Macintosh.
Install on Multiple Computers
You can install a base package on all the computers that you want to protect, and then perform the necessary configurations from the CommCell Console. For more information, see Installing Commvault on All the Computers Across Your Organization.
To review other installation options to deploy the Commvault software, see Additional Installations Operations Using the Installation Package.
